Universal File System Driver
Technology From Paragon Enables Access and File Sharing Between PCs,
Clients and Servers -- Regardless of Operating System
IRVINE, CA--(Marketwire - December 21, 2009) - In keeping with its commitment to enable
seamless communication between operating systems, Paragon Software Group (PSG),
the technology leader in storage management solutions, today announced
support for the new RangeMax™ Wireless-N Gigabit Router with USB
(WNR3500L) from NETGEAR®, a worldwide provider of technologically
innovative, branded networking solutions.
Paragon NTFS for Linux will provide full access to a Windows
(NTFS-formatted) hard drive attached to NETGEAR's WNR3500L open source
router -- enabling all clients and servers, regardless of their operating
system, to access and share files to and from the drive via the WNR3500L
router.
"Paragon has enthusiastically responded to NETGEAR's open source router
initiative to provide enhanced capabilities to our user community -- by
embedding a full version (not a trial version) of their Universal File
System Driver (UFSD) technology into our router," said NETGEAR's Som Pal
Choudhury, senior product line manager, advanced wireless division. "This
version of UFSD, called Paragon NTFS for Linux, enables full high
performance read/write access to a Windows (NTFS-formatted) external hard
drive attached to the USB port of the NETGEAR WNR3500L Router, and allows
all PCs, clients and servers on the network, running Windows, Mac, Linux,
etc, to share files to the NTFS-formatted HDD attached to our router --
regardless of their Operating System."
Paragon Software has been chosen to join NETGEAR's Development Partner
Program, which includes select software application vendors that are
creating custom applications for the WNR3500L router that NETGEAR customers
can download. The NETGEAR WNR3500L is supported by a dedicated open source
router community, http://www.myopenrouter.com, which provides open source
firmware downloads, applications, forums, blogs, articles, source code, and
user guides. Members also have access to dedicated and responsive support
from open source experts.
"We are extremely pleased to be asked to join the community of developers
in NETGEAR's Development Partner Program, and to help harness the power of
Open Source," noted Tom Fedro, president for Paragon Software Group.
"Paragon's NTFS for Linux provides full performance, high speed file
sharing to NTFS-formatted USB hard drives, an important feature for NETGEAR
customers that we are happy to provide."
Key facts and features for Paragon's NTFS for Linux include:
Â
- Full read/write access: Read, modify, delete, and create or copy files.
- Easy to install: The driver is easily installed through a user-friendly wizard, with no additional configuration required after installation.
- Easy to use: Mount any NTFS partition like a native one -- no need to perform special commands to get access.
- Supports non-roman characters and languages: File and folder names in national languages, including Chinese, Korean, Japanese, and Russian.
- No system degradation during data transfers.
- Based on Paragon's own unique Universal File System Driver (UFSD)technology, specially developed to provide full high-performance access to volumes of the most popular file systems (NTFS, HFS+, Ext2/3, FAT, etc.) under various platforms (Windows, Mac, Linux, DOS, etc.) where these file systems otherwise would not be supported.
Download the Paragon Networks Firmware for NETGEAR WNR3500L
Category:
The Linux version of Paragon NTFS is now embedded in the WNR3500L router's Universal File System Driver (UFSD), says Netgear. The embedded version is said to include a "full version (not a trial version)" of the UFSD, which is likely based on Paragon NTFS for Linux 7.0 Embedded Solution, This version appears to be similar to the free "Express" version of Paragon NTFS (see image farther below). Paragon also sells a $100 Professional version, which includes additional RAID drivers and Linux utilities.
Regards.
Gary Corbett
Based on Paragon's own unique Universal File System Driver (UFSD) technology, developed to provide full high-performance access to volumes of the various file systems like NTFS, HFS+, Ext2/3, and FAT, under various platforms (Windows, Mac, Linux, DOS, etc.) where these file systems otherwise would not be supported.
Gary Corbett
Storage solutions manufacturer Paragon Software Group says it now supports the RangeMax Wireless-N Gigabit opensource router from Netgear. air purifier reviews
I was looking at many routers and some with USB ports for HDs only supported FAT drives. I'm glad to see this one support NTFS. It's pretty much the standard on Windows machines and a much better file system then FAT32.web design
The new version is even greater than the older ones just as expected. I hope to see more of them in the future.
Video Boss Review
I bought NETGEAR WNR3500L Router about a month ago and had some temporary issues with the installation, but nothing bad at all.
lifetime video profits review
Paragon NTFS for Linux include also supports non-Roman characters and languages, including files and folders in local languages, including Chinese, Korean, Japanese and Russian. Also, do not lead to any degradation of the system during data transfer.Rakeback | Rakeback | Rakeback
A great blog and very helpfull post. I think Nursing is a good Career
Thanks for sharing this. and A very excellent post..It's very helpful thanks for this good advices.. I was so impressed and happy. nice work
Web Development
Web Development
That's great. Router NETGEAR WNR3500L bought a month ago and had some temporary problems with the installation, but there's nothing wrong at all. Overall a very good product, worth the money. Thanks for sharing the information. Regards, essays term papers
