Question about loading custom settings file.
7 posts / 0 new
silvery
Is there any way to load nvrambak.bin (created via web interface "backup" option) and apply it on router by some command when connected via telnet/SSH?
Subhra
Yes it is possible ....
1. Transfer the backup file on the board (via ftp/scp).
2. Next use the following command on the board console (through telnet/ssh) to restore the configuration...
* nvram restore path_of_backup_file
But I would rather suggest you to use WebUI to restore the router settings.
silvery
Found great tools here:http:/
http://infodepot.wikia.com/wiki/OTRW_Package_Tutorial#Backup.2FRestore_o...
testing this solution now...
silvery
Thanks a lot for that. But is
Thanks a lot for that. But is there any command exist to backup settings before performing the steps from your recommended procedure also using telnet/ssh?
(I found a script, but is there any built-in command for that, such as nvram one?)
silvery
Subhra said: Yes it is
Subhra said: Yes it is possible .... 1. Transfer the backup file on the board (via ftp/scp). 2. Next use the following command on the board console (through telnet/ssh) to restore the configuration... * nvram restore But I would rather suggest you to use WebUI to restore the router settings.
Subhra
yes, you can take backup of
yes, you can take backup of current settings using the following command ..
* nvram backup name_of_backup_file
The backup file will be created on the board. You have to transfer it to your machine.
silvery
Subhra said: yes, you can
Subhra said: yes, you can take backup of current settings using the following command .. * nvram backup name_of_backup_file The backup file will be created on the board. You have to transfer it to your machine.
Thank you very much!
