Question about logging system and use of external HDD.
5 posts / 0 new
silvery
silvery's picture
Hi. The point is to completely decrease the use of external HDD by system. I already disabled samba logging, but it seem to be isn't enought, so I got the couple of questions:
1)Is there a possibility to completely disable all logging in DD-WRT (I'm using dd-wrt.v24-14896_NEWD-2_K2.6_big.bin). The point is to completely decrease the use of external HDD by system.
2)Can I disable linux swap on wnr3500l somehow(I guess there's pretty much RAM onboard for that)?
Subhra
Subhra's picture
I am not able to understand
I am not able to understand your problem clearly. Can you please elaborate on that?
If I have not misunderstood, you want to disable all kind of remote login facilities, and you can easily do that from router WebUI (Administration -> Management -> Remote Access).
silvery
silvery's picture
Subhra said: I am not able to
Subhra said: I am not able to understand your problem clearly. Can you please elaborate on that? If I have not misunderstood, you want to disable all kind of remote login facilities, and you can easily do that from router WebUI (Administration -> Management -> Remote Access).
Sorry, I meant to disable all event logging and not logging into system (which is of course already disabled in "Remote Access" settings).
Subhra
Subhra's picture
Subhra
Subhra's picture
Are you trying to prevent
Are you trying to prevent generation of logs by various daemons(viz. samba) running on the board?
For that case, there is a daemon named "syslogd", which helps various application to maintain their log. You can try killing that daemon for your purpose(though it depends if that particular application uses syslog utility to maintain its log or not).
