Kong just told me you can go here to find his latest builds:
Here's the convo:
Blujay:
Can you please tell me what your latest build is and where to find it? Do you have a download site like Toastman?
Kong:
From now on you should checkout:
Here's the convo:
Blujay:
Kong:
In addition to that. I intend to publish selected builds that are well tested to myopenrouter.
this reeks of a hack job no thx
can a mod or administraor verify that kongs account has not be compermised
I ADVISE EVERY ONE STAY AWAY FROM THAT SITE untill someone does the above
~/why would kong tell you to tell us that why would he not just post it him self.....
hax I say HACKS
this has nothing todo with trusting kong it strikes me as very odd that he would have someone tell us in-his place instead of telling us him self
He didn't have someone tell us. Someone (Blujay) just wrote what he says Kong told him. So you are right to question someone else's hearsay post.
But Kong did reply directly after the post and did not say the info above was incorrect.
In Kong's post regarding the latest firmware.
http://www.myopenrouter.com/forum/thread/32968/Kong-Mod-Update-build-17940
You will see he does indeed point to http://www.desipro.de/ddwrt as where to find all his files.
Hi OneMoar,
BlueJay sent me a private message in which he asked where to look for the latest builds, since I now create builds for routers that are not advertised here, I have decided to put all of my builds on a server I maintain and from time to time update the builds on myopenrouter that are specific for the wnr3500l.
So I told him that he can always check at my location for new builds.
If you check earlier announcements and the download locations they have been pointing there already, but with direct links to the specific .bin
derp sry forgive my paranoia .....
