Just an Update....
I've been using the vpn build 17940 for a few days on 2 E3000. On my network the E3000 is a wired Gateway (wireless disable). I use this build because of Privoxy, VLAN and QoS. I use Build 15962 on all my wireless 2.4Ghz AP & VAP and WDS 5Ghz at home (E2000, wrt610v1(k24 build) & wrt320) it's working great.
The other E3000 is a family member's router and I have set it up with Wireless, VAP, Privoxy, VLAN and QoS. In the past with build 15962 using NG-Mixed Mode and Enabled Bluetooth Coexistence, wireless worked great. Now with these new wireless drivers these settings in less than a day the wireless speed will drop down to 6.5Mbps. I have been trying new settings and so far using Mixed Mode and Preemption Bluetooth Coexistence is working better and not dropping the rates to minimum so far.
Kong, BrainSlayer seems to have made the newest Broadcom wireless drivers available. Hopefully this will fix the wireless issues on your next build.
http://svn.dd-wrt.com:8000/ticket/2299#comment:1
@Koooooong...
We are dying over here.... how about a set of builds with the OLD drivers, then one with the New-New driver that BS just committed in response to your ticket so we can test test test.
Thank you Sir!
I will start testing r18010 later tonight.
Can you give us a quick run down of what is included on this build?
Thanks for the new build Kong, wireless performance seems improved, and hopefully performance will not degrade over time in few days like previous builds.
I went ahead and created a thread on the DD-WRT section so we can discuss this new release there.
http://www.myopenrouter.com/forum/thread/34165/New-Kong-Mod-Release-r180...
I upgraded to build 18050M stdkong yesterday on my E3000. I had previously been running dd-wrt.v24-16785_NEWD-2_K2.6_big-e2k-e3k.bin but wanted to get the DLNA support. Everything seemed to go fine, however, I had a bridged guest network which is no longer working. Clients can connect but cannot get out to the internet so I'm not sure what broke or how to fix it. Any suggestions?
Use Kong Build 18010M. I found that VLAN Internet Access was broken in 18050M.
is this the optware repo?
http://downloads.openwrt.org/backfire/10.03.1-rc6/brcm47xx/packages/
hi,
thanks for the great mod. I tried to get ushare working on the eko build and failed badly ^^. (i already found the thread where it is explained why).
But, could i have the toolchain for this? I would like to compile some packages for my Router and i don't know which patches you have included. A little explanation or the toolchain itself would be enough ^^
