WNR3500L with DD-WRT stopped working after 1 year
4 posts / 0 new
nicolasd
hello,
something very unusual has happened to me.
my router stopped working for no reason after more then 1 year.
i have not changed any setting for over 6 months.
as i was using DD-WRT (not sure which version) i am wondering if it is possible to rescue this router.
has another user experienced similar oddity?
thanks,
Brandon C
What do you mean "stopped
What do you mean "stopped working'? Does it not light up or even turn on? Can you not reset it?
nicolasd
it turns ONE light on.
but it does not start dhcp server as it used to.
i can connect network cables and the respective light will not light up at the front.
any suggestion?
PetervdM
check / try with another
check / try with another power supply
