hi all
3 posts / 0 new
j79
hi all
I'm new here. Just bought a WNR3500lv1 about two weeks ago.
My project is to encrypt all my house using OpenVPN.
So I thought try DD-WRT first but...
With the orginal firmware from netgear (v1.2.2.44_35.0.53) i have a wifi problem. All my devices are disconnecting as described ih this post
http://forum1.netgear.com/showthread.php?t=30992
Is anybody know if this problem is solved with all alternative firmwares ?
thanks for your advices.
jé'
j79
I tried to change my channel
I tried to change my channel to 3 as my wifi was on the same channel same a neighbour one, the 6.
I'll make some tests before to deactivate all security.
j?'
j79
Sorry I would have answered earlier.
After having changed the channel everything seems OK. No more disconnections.
As my neighbour doesn't use its wifi I asked him to turn off his access point.
So now let's think about my encryption project.
Thanks very much.
jé'
