3500L USB File transfer
4 posts / 0 new
munu
I just installed DD-WRT with USB support on my 3500L router. Everything is working fine so far. I am able to access internet and I also did USB setups and I can access my USB drive if I go to ftp://192.168.1.1:21.
Now my question is how can I copy files from my PC to this USB drive. Earlier with Netgear version I used to have a shared drive in window explorer and it was drag and drop. How it works with the DD-WRT. I can view the files on USB but not sure how to copy more files.
Please help
Subhra
Which firmware are you using
Which firmware are you using ??? Can you please give me the link to download the same???
munu
I took it from the FW guide
I took it from the FW guide section
Subhra
It will be great if you
It will be great if you provide the exact download link.
