Wireless MAC address filtering to restrict access in Tomato
4 posts / 0 new
Sorv
I am considering Tomato and would like to know if it allows restricting access to the wireless LAN only to the MAC addresses one can enter in the list (like in the stock Linksys firmware). If yes, then what's the maximum number of these addresses? Will enabling this restriction (if possible) adversely affect the performance? Many thanks!
Toastman
On the current Toastman
On the current Toastman firmware up to 250 wireless restrictions are supported.
Sorv
Tathagata Das said: If I
Tathagata Das said: If I remember correctly then Tomato provides one page through which you can configure Wireless access control list. Now it is up to the wireless driver whether it supports such feature or not. Which router and what wireless driver are you using ?
I am thinking of using TomatoUSB on WNR3500L.
Sorv
Toastman said: On the current
Toastman said: On the current Toastman firmware up to 250 wireless restrictions are supported.
If I have about 50 allowed MAC addresses, does it mean that I have to create 50 separate rules (not a single rule with 50 addresses)? Would it have a noticeable  impact on performance? Thanks!
