Hi all,
I have seen that many people are facing problems in building DDWRT firmware for WNR3500Lv2. I have been able to build it. Here I am sharing the steps I followed to perform the same.
[NOTE:- This method requires to have both 32-bit and 64-bit machine.]
Step 1: Download toolchain to compile ddwrt.
Step 2: Perform the following modification in "toolchain-mipsel_gcc4.1.2/mipsel-linux-uclibc/sys-include/regex.h" file in toolchain.
Original Code :-
#if !defined _POSIX_C_SOURCE && !defined _POSIX_SOURCE && defined VMS
/* VMS doesn't have `size_t' in , even though POSIX says it
should be there. */
# include <stddef.h>
#endif
Modified Code :-
should be there. */
#endif
Step 3: Download "DD-WRT Source Code (Used in WNR3500Lv2 Firmware Build)" from this link and untar it using following command,
$ tar -zxvf dd-wrt.tgz
Step 4: Download the "DD-WRT for WNR3500Lv2 Initial Release 1.0" from this link.
Step 5: Untar "DDWRT_WNR3500Lv2_Final_Release_09-12-2011.tgz" using following command,
$ unzip DDWRT_WNR3500Lv2_Final_Release_09-12-2011.tgz.zip
$ tar -zxvf DDWRT_WNR3500Lv2_Final_Release_09-12-2011.tgz
Go to DDWRT_WNR3500Lv2_Final_Release_09-12-2011 using following command,
$ cd DDWRT_WNR3500Lv2_Final_Release_09-12-2011
Make DD-WRT source code ready for Netgear WNR3500Lv2 using the following command,
$ sh ddwrt_build_wnr3500lv2.sh
Step 6: Perform the following modification the "dd-wrt/src/router/rules/pppoe.mk" file
Original Code:-
pppoe pppoe-%:
@true
Modifed Code:-
pppoe-%:
@true
Step 7: Perform the follwoing modifiaction the "dd-wrt/src/router/busybox/Makefile" file
Line 421:-
Original Code:-
config %config: scripts_basic outputmakefile FORCE
$(Q)mkdir -p include
Modifed Code:-
Line 1273:-
Original Code:-
/ %/: prepare scripts FORCE
$(Q)$(MAKE) KBUILD_MODULES=$(if $(CONFIG_MODULES),1) \
Modified Code:-
Step 8: Export toolchain path.
Step 9: Go to "dd-wrt/src/router".
Step 10: Use the following command to compile the source code,
"make -f Makefile.wnr3500lv2 configure all install"
[Note: This step should be performed in a 64-bit machine. I have used Fedora Core 15 for this purpose.]
Step 11: After successful compilation download following utility and use these series of commands,
[Note: These steps should be performed in a 32-bit machine. I have used Fedora Core 14 for this purpose.]
$ tar -zxvf DD-WRT_Image_Creation.tgz
$ cd DD-WRT_Image_Creation
$ sh ddwrt_image.sh
If everything goes well you should find the firmware ("ddwrt-wnr3500lv2.chk") in same ("DD-WRT_Image_Creation") directory.
@Tathagata: Thank you for pointing out the shortcoming of this document.
Step 1:
Toolchain can be downloaded from this link.
Step 8:
Use the following command to export your toolchain path.
export PATH=/TOOLCAHIN_BASE_PATH/toolchain-mipsel_gcc4.1.2/bin:$PATH
In my case I have downloaded the toolchain in "/opt" so for me the command was ,
export PATH=/opt/toolchain-mipsel_gcc4.1.2/bin:$PATH
Step 10:-
For compiling first time use the command,
and for further compilation use following command,
"make -f Makefile.wnr3500lv2 configure clean all install"
Fisrt, thank you for your post. I would like to know which is differences between DDWRT_WNR3500Lv2_Final_Release_09-12-2011 and the firmware that I can make with your post and code source ?
And, for the Linux distribution, can I use Debian 6 (32 and 64) ?
Thank you
The sample firmware supplied with the "DDWRT_WNR3500Lv2_Final_Release_09-12-2011" and the firmware generated by the above procedure would be same.
Theoretically Debian may be used for the compilation provided all basic development tools are installed. But I personally never did the same.
New dd-wrt for WNR3500Lv2 is released. It needs just one 64 bit machine to compile the firmware. You will find this build here.
I need your help
My OS is redhat 2.6.18
while " make -f Makefile.wnr3500lv2 install"
../wnrtool/trx -o /data/lchm/DDWRT_WNR3500Lv2_Final_Release_09-12-2011/dd-wrt/src/image/ddwrt-wnr3500lv2.trx /data/lchm/DDWRT_WNR3500Lv2_Final_Release_09-12-2011/dd-wrt/src/image/vmlinux.lzma mipsel-uclibc/rootfs.squashfs
mjn3's trx replacement - v0.81.1
cd /data/lchm/DDWRT_WNR3500Lv2_Final_Release_09-12-2011/dd-wrt/src/image && ./../wnrtool/packet -k ddwrt-wnr3500lv2.trx -f ./../router/netgear/emptyfile -b ./../wnrtool/comp-wnr3500lv2.txt -ok kernel_image -oall ddwrt-wnr3500lv2 -or rootfs_image -i ./../router/netgear/ambitCfg-wnr3500.h && \
rm -f rootfs_image.chk kernel_image.chk
./../wnrtool/packet: /lib64/libc.so.6: version `GLIBC_2.7' not found (required by ./../wnrtool/packet)
make: *** [install] Error 1
I need your help.
I have " make -f Makefile.wnr3500lv2 install" pass in CentOs6.2
Nice to hear that things are working ... please share how did you overcome this.
by "./../wnrtool/packet: /lib64/libc.so.6: version `GLIBC_2.7' not found (required by ./../wnrtool/packet)"
I only use CentOs6.2 instead of Redhat5.2
Hello, Subhra.
Thank you very much for this tutorial.
I am using Ubuntu 32 and 64 for this purpose.
I made these steps, except step 1 that i was not be able to download from your link and i used one that i download on dd-wrt current-toolchains.tar.
When i made "make -f Makefile.wnr3500lv2 configure all install" next errors were catched
bohdan@bohdan-laptop:~/dd/dd-wrt/src/router$ make -f Makefile.wnr3500lv2 configure clean all install
rules/iptables.mk:43: warning: overriding commands for target `iptables-clean'
rules/iptables.mk:2: warning: ignoring old commands for target `iptables-clean'
rules/all.mk:121: rules/mmc-ixp4xx.mk: No such file or directory
rules/all.mk:198: rules/strace.mk: No such file or directory
rules/all.mk:209: rules/oled.mk: No such file or directory
rules/all.mk:219: /home/bohdan/dd/dd-wrt/src/router/private/ath9k-rules/ath9k.mk: No such file or directory
rules/all.mk:223: rules/atm.mk: No such file or directory
[ ! -d rules/atm.mk ] || make -C rules/atm.mk
[ ! -d /home/bohdan/dd/dd-wrt/src/router/private/ath9k-rules/ath9k.mk ] || make -C /home/bohdan/dd/dd-wrt/src/router/private/ath9k-rules/ath9k.mk
[ ! -d rules/oled.mk ] || make -C rules/oled.mk
[ ! -d rules/strace.mk ] || make -C rules/strace.mk
[ ! -d rules/mmc-ixp4xx.mk ] || make -C rules/mmc-ixp4xx.mk
[ ! -d nvram-configure ] || make -C nvram-configure
[ ! -d libutils-configure ] || make -C libutils-configure
[ ! -d shared-configure ] || make -C shared-configure
[ ! -d matrixssl-configure ] || make -C matrixssl-configure
[ ! -d httpd-configure ] || make -C httpd-configure
[ ! -d rc-configure ] || make -C rc-configure
[ ! -d services-configure ] || make -C services-configure
[ ! -d www-configure ] || make -C www-configure
[ ! -d lib.mipsel-configure ] || make -C lib.mipsel-configure
[ ! -d bridge-configure ] || make -C bridge-configure
[ ! -d zlib-configure ] || make -C zlib-configure
make -j 4 -C zlib
make[1]: Entering directory `/home/bohdan/dd/dd-wrt/src/router/zlib'
mipsel-linux-uclibc-gcc -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fPIC -DUSE_MMAP -ffunction-sections -fdata-sections -Wl,--gc-sections -c -o example.o example.c
mipsel-linux-uclibc-gcc -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fPIC -DUSE_MMAP -ffunction-sections -fdata-sections -Wl,--gc-sections -c -o adler32.o adler32.c
mipsel-linux-uclibc-gcc -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fPIC -DUSE_MMAP -ffunction-sections -fdata-sections -Wl,--gc-sections -c -o compress.o compress.c
mipsel-linux-uclibc-gcc -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fPIC -DUSE_MMAP -ffunction-sections -fdata-sections -Wl,--gc-sections -c -o crc32.o crc32.c
example.c:8:19: error: stdio.h: No such file or directory
In file included from zlib.h:34,
from example.c:9:
zconf.h:288:41: error: sys/types.h: No such file or directory
zconf.h:289:52: error: unistd.h: No such file or directory
In file included from example.c:9:
zlib.h:1183: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'gzseek'
zlib.h:1208: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'gztell'
zlib.h:1276: error: expected declaration specifiers or '...' before 'off_t'
zlib.h:1301: error: expected declaration specifiers or '...' before 'off_t'
example.c:12:22: error: string.h: No such file or directory
example.c:13:22: error: stdlib.h: No such file or directory
from zutil.h:17,
from crc32.c:29:
In file included from zutil.h:17,
from crc32.c:29:
from compress.c:9:
In file included from compress.c:9:
from adler32.c:9:
In file included from adler32.c:9:
example.c: In function 'test_compress':
example.c:64: warning: incompatible implicit declaration of built-in function 'strlen'
example.c:67: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:67: error: 'stderr' undeclared (first use in this function)
example.c:67: error: (Each undeclared identifier is reported only once
example.c:67: error: for each function it appears in.)
example.c:67: warning: incompatible implicit declaration of built-in function 'exit'
example.c:69: warning: incompatible implicit declaration of built-in function 'strcpy'
example.c:72: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:72: warning: incompatible implicit declaration of built-in function 'exit'
example.c:75: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:76: warning: incompatible implicit declaration of built-in function 'exit'
example.c:78: warning: incompatible implicit declaration of built-in function 'printf'
example.c: In function 'test_gzio':
example.c:94: warning: incompatible implicit declaration of built-in function 'strlen'
example.c:96: error: 'off_t' undeclared (first use in this function)
example.c:96: error: expected ';' before 'pos'
example.c:99: error: 'NULL' undeclared (first use in this function)
example.c:100: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:100: error: 'stderr' undeclared (first use in this function)
example.c:101: warning: incompatible implicit declaration of built-in function 'exit'
example.c:105: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:106: warning: incompatible implicit declaration of built-in function 'exit'
example.c:109: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:110: warning: incompatible implicit declaration of built-in function 'exit'
example.c:117: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:118: warning: incompatible implicit declaration of built-in function 'exit'
example.c:120: warning: incompatible implicit declaration of built-in function 'strcpy'
example.c:123: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:124: warning: incompatible implicit declaration of built-in function 'exit'
example.c:127: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:128: warning: incompatible implicit declaration of built-in function 'exit'
example.c:130: warning: incompatible implicit declaration of built-in function 'printf'
example.c:133: error: 'pos' undeclared (first use in this function)
example.c:135: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:137: warning: incompatible implicit declaration of built-in function 'exit'
example.c:141: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:142: warning: incompatible implicit declaration of built-in function 'exit'
example.c:146: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:147: warning: incompatible implicit declaration of built-in function 'exit'
example.c:152: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:153: warning: incompatible implicit declaration of built-in function 'exit'
example.c:156: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:157: warning: incompatible implicit declaration of built-in function 'exit'
example.c:159: warning: incompatible implicit declaration of built-in function 'printf'
example.c: In function 'test_deflate':
example.c:175: warning: incompatible implicit declaration of built-in function 'strlen'
example.c:182: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:182: error: 'stderr' undeclared (first use in this function)
example.c:182: warning: incompatible implicit declaration of built-in function 'exit'
example.c:190: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:190: warning: incompatible implicit declaration of built-in function 'exit'
example.c:197: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:197: warning: incompatible implicit declaration of built-in function 'exit'
example.c:201: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:201: warning: incompatible implicit declaration of built-in function 'exit'
example.c: In function 'test_inflate':
example.c:214: warning: incompatible implicit declaration of built-in function 'strcpy'
example.c:225: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:225: error: 'stderr' undeclared (first use in this function)
example.c:225: warning: incompatible implicit declaration of built-in function 'exit'
example.c:231: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:231: warning: incompatible implicit declaration of built-in function 'exit'
example.c:235: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:235: warning: incompatible implicit declaration of built-in function 'exit'
example.c:238: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:239: warning: incompatible implicit declaration of built-in function 'exit'
example.c:241: warning: incompatible implicit declaration of built-in function 'printf'
example.c: In function 'test_large_deflate':
example.c:260: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:260: error: 'stderr' undeclared (first use in this function)
example.c:260: warning: incompatible implicit declaration of built-in function 'exit'
example.c:271: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:271: warning: incompatible implicit declaration of built-in function 'exit'
example.c:273: warning: incompatible implicit declaration of built-in function 'fprintf'
adler32.c: In function 'adler32_combine':
adler32.c:131: error: expected declaration specifiers before 'off_t'
adler32.c:132: error: number of arguments doesn't match prototype
zlib.h:1276: error: prototype declaration
example.c:274: warning: incompatible implicit declaration of built-in function 'exit'
example.c:282: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:282: warning: incompatible implicit declaration of built-in function 'exit'
example.c:289: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:289: warning: incompatible implicit declaration of built-in function 'exit'
example.c:293: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:294: warning: incompatible implicit declaration of built-in function 'exit'
example.c:297: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:297: warning: incompatible implicit declaration of built-in function 'exit'
example.c: In function 'test_large_inflate':
example.c:310: warning: incompatible implicit declaration of built-in function 'strcpy'
example.c:320: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:320: error: 'stderr' undeclared (first use in this function)
example.c:320: warning: incompatible implicit declaration of built-in function 'exit'
example.c:327: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:327: warning: incompatible implicit declaration of built-in function 'exit'
example.c:331: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:331: warning: incompatible implicit declaration of built-in function 'exit'
example.c:334: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:335: warning: incompatible implicit declaration of built-in function 'exit'
example.c:337: warning: incompatible implicit declaration of built-in function 'printf'
example.c: In function 'test_flush':
example.c:350: warning: incompatible implicit declaration of built-in function 'strlen'
example.c:357: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:357: error: 'stderr' undeclared (first use in this function)
example.c:357: warning: incompatible implicit declaration of built-in function 'exit'
example.c:364: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:364: warning: incompatible implicit declaration of built-in function 'exit'
example.c:371: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:371: warning: incompatible implicit declaration of built-in function 'exit'
example.c:374: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:374: warning: incompatible implicit declaration of built-in function 'exit'
example.c: In function 'test_sync':
example.c:389: warning: incompatible implicit declaration of built-in function 'strcpy'
example.c:399: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:399: error: 'stderr' undeclared (first use in this function)
example.c:399: warning: incompatible implicit declaration of built-in function 'exit'
example.c:405: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:405: warning: incompatible implicit declaration of built-in function 'exit'
example.c:409: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:409: warning: incompatible implicit declaration of built-in function 'exit'
example.c:413: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:415: warning: incompatible implicit declaration of built-in function 'exit'
example.c:418: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:418: warning: incompatible implicit declaration of built-in function 'exit'
example.c:420: warning: incompatible implicit declaration of built-in function 'printf'
example.c: In function 'test_dict_deflate':
example.c:438: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:438: error: 'stderr' undeclared (first use in this function)
example.c:438: warning: incompatible implicit declaration of built-in function 'exit'
example.c:442: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:442: warning: incompatible implicit declaration of built-in function 'exit'
example.c:449: warning: incompatible implicit declaration of built-in function 'strlen'
example.c:453: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:454: warning: incompatible implicit declaration of built-in function 'exit'
example.c:457: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:457: warning: incompatible implicit declaration of built-in function 'exit'
example.c: In function 'test_dict_inflate':
example.c:470: warning: incompatible implicit declaration of built-in function 'strcpy'
example.c:480: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:480: error: 'stderr' undeclared (first use in this function)
example.c:480: warning: incompatible implicit declaration of built-in function 'exit'
example.c:490: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:491: warning: incompatible implicit declaration of built-in function 'exit'
example.c:496: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:496: warning: incompatible implicit declaration of built-in function 'exit'
example.c:500: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:500: warning: incompatible implicit declaration of built-in function 'exit'
example.c:503: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:504: warning: incompatible implicit declaration of built-in function 'exit'
In file included from crc32.c:29:
zutil.h:23:22: error: string.h: No such file or directory
zutil.h:24:22: error: stdlib.h: No such file or directory
zutil.h:38:23: error: errno.h: No such file or directory
example.c:506: warning: incompatible implicit declaration of built-in function 'printf'
example.c: In function 'main':
example.c:524: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:524: error: 'stderr' undeclared (first use in this function)
example.c:525: warning: incompatible implicit declaration of built-in function 'exit'
example.c:528: warning: incompatible implicit declaration of built-in function 'fprintf'
example.c:531: warning: incompatible implicit declaration of built-in function 'printf'
example.c:534: warning: incompatible implicit declaration of built-in function 'calloc'
example.c:541: warning: incompatible implicit declaration of built-in function 'exit'
make[1]: *** [adler32.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [compress.o] Error 1
make[1]: *** [example.o] Error 1
In file included from /home/bohdan/toolchain-mipsel_gcc4.1.2/bin/../lib/gcc/mipsel-linux-uclibc/4.1.2/include/syslimits.h:7,
from /home/bohdan/toolchain-mipsel_gcc4.1.2/bin/../lib/gcc/mipsel-linux-uclibc/4.1.2/include/limits.h:11,
from crc32.c:36:
/home/bohdan/toolchain-mipsel_gcc4.1.2/bin/../lib/gcc/mipsel-linux-uclibc/4.1.2/include/limits.h:122:61: error: limits.h: No such file or directory
crc32.c: In function 'crc32_combine':
crc32.c:373: error: expected declaration specifiers before 'off_t'
crc32.c:374: error: number of arguments doesn't match prototype
zlib.h:1301: error: prototype declaration
make[1]: *** [crc32.o] Error 1
make[1]: Leaving directory `/home/bohdan/dd/dd-wrt/src/router/zlib'
make: *** [zlib] Error 2
Thank you for any tips.
I guess problem is some how related to toolchain. Try to download the toolchain the from link again, link is still alive.
I haven't compiled it on a ubuntu machine. Is it possible for you to compile it on a fedora machine?
Thank you a lot for your help.
I download toolchain from your link now and it looks the same that i had earlier. However it has no directory toolchain-mipsel_gcc4.1.2/mipsel-linux-uclibc/sys-include/ to apply step 2...
I think to install fedora on virtual machine. Are there some tools/packages that i need to obtain/install before proceed to compile?
See this link for the requirements.
Hi All,
Please help me how to build dd-wrt for Linksys e3200, I have the source and tool chain. I am confused like which make file I should use.
in src/router there are many but non corresponds to e3200, please help me how should i build.
Thanks in advance.
@gvk: you will get better feedback on e3200 in ddwrt forum.
Hi Subhra,
thank you for your guide. I followed it step by step (with minor modifications in linux kernel cause I wanted bridge.ko as a module not integrated in kernel) and i managed to cross compile it. I successfully upgraded the router firmware but the only problem i get is that it doesn't recognoze the usb stick. Even the option of jffs2 support does not appear in the web interface. Is it normal or am I missing something?
Sanadrea
jffs2 support is not provided in this build. USB Should work.
Which file-system you are using for your USB Stick??
Hi I am using ext2 as file system, because i need some symlinks.
Do we soon see the openwrt available for WNR3500v2 ?
Someone made a patch that they need help testing here...
http://www.mail-archive.com/[email protected]/msg16616.html
