After installing the dd-wrt mini firmware got a brick. Lights amber, no ping, says that cable is not connected, all the ports do not answer(tried other cables). Booting stops, but the tftp runs through the console or by short pins(flashing green).
Is there a way to load the firmware without a network cable?
Sorry for bad english.
The console responds this:
Decompressing..........done
CFE for WNR3500L version: v1.0.36
Build Date: Tue Aug 11 15:09:14 CST 2009
Init Arena
Init Devs.
Found a 8MB ST compatible serial flash
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.10.56.28
CPU type 0x19740: 133MHz
Tot mem: 65536 KBytes
Device eth0: hwaddr E0-91-F5-DA-7B-CE, ipaddr 192.168.1.1, mask 255.255.255.0
Checksum mismatch:
Image chksum: 0xAC9AEFC4
Calc chksum: 0x073CEF4B
Loading: .. 3856 bytes read
Entry at 0x80001000
Closing network.
Linux version 2.6.24.111 (eko@dd-wrt) (gcc version 4.1.2) #409 Wed Apr 7 18:17:14 CEST 2010
CPU revision is: 00019740
Determined physical RAM map:
memory: 04000000 @ 00000000 (usable)
Built 1 zonelists in Zone order. Total pages: 16256
Kernel command line: console=ttyS0,115200 root=1f02 rootfstype=squashfs noinitrd
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 256 (order: 8, 1024 bytes)
CPU: BCM4716 rev 1 at 133 MHz
Using 66.500 MHz high precision timer.
console [ttyS0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 59800k/65536k available (3121k kernel code, 5676k reserved, 1478k data, 144k init, 0k highmem)
Generic PHY: Registered new driver
PCI: Using membase 8000000
PCI: Initializing host
PCI: Reset RC
Stops at this
There is a good guide on how to restore a JTAG?
Hope this link may help you regarding your jtag quaries.
why you want to restore with a JTAG? Have you tried reset to defaults to recover your router or some other methods ??
All Other methods are not suitableall and ends that I need a network connection to flash. But as I said before, the network is not initialized, probably corrupted bootloader(CFE).
again, sorry for bad english
Do the following steps,
1. Give a static ip to your PC (192.168.1.X)
2. Connect your PC to Router LAN port.
3. ping to 192.168.1.1
Are you getting some response ??
If yes, then hopefully your bootloader is not corrupted.
Of course not. The network(network cable is not plugged, says to me the operating system) does not work on the router, if it worked, I would have flashed through tftp. Hardware fault should not be, it happened immediately after unsuccessful flash firmware dd-vrt. I've tried to explain earlier. I also found it strange that line:
CPU type 0x19740: 133mhz
But I have already collected jtag cable, and now try to fill through it cfe and firmware.
What is the status of your router currently ??
Have you performed the jtag operation ??
I could not get data from the microprocessor. Probably not right soldered. Since it is not found for NETGEAR WNR3500L scheme, made a connection with this scheme http://www.myopenrouter.com/article/10935/Creating-a-JTAG-Cable-For-WGR6...
If i can not find JTAG pinouts scheme, he will seek, through the datasheet.
The problem finally solved, did not have to JTAG. Finished from the CFE loader "nvram erase" and reboot, then flashed the firmware, all got. It turned easily.
Good to know that things are working at your end. Which firmware have you used to upgrade with??
ORIGINAL v54 >> DD-WRT "Mini" BETA svn 14826 >> 1.9.2.7-rtn-r4330(wl500g Oleg's Firmware)
Brick occurred on DD-WRT. But after a "nvram erase" everything works. USB-TTL cable is useful.
