How to Hide SSID of Virtual interface, repeater mode - Help
2 posts / 0 new
leegold
Hi, I have a Linksys wrt54gs v2.1 with DD-WRT v24-sp2 it's set up as a repeater. I want to hide the SSID of the virtual interface wl01 which is dd-wrt_vap, I selected Disable for Wireless SSID Broadcast in the menu and saved, applied settings and rebooted the unit. But it still shows up on all wifi remote interfaces, but I want it to be hidden. I turned off the repeater to "rest" it. Rebooted remote PCs. Still shows as a visiable SSID. How do I do this? Thanks
buddee
hrm, which build number are
hrm, which build number are you using on that unit? also, are wl0 and wl0.1's MAC address the same? Can check by looking in Wireless > Basic Settings, if they are, its going to be quite hard to hide it.
