I'm new here (and my English is weak). I've tried to first find an answer in other topics, without success so I'm starting a new thread.
I'm using Tomato by Shibby (BT-VPN if relevant) and so far so good. The Wifi LED remains on even when Wifi is off, but that's not a big deal for me. What I find annoying though, is that I cannot toggle Wifi on/off using the backside button: I have to do this through the Web UI and then have to start the main (wired) PC.
Is there any plan to fix this or is there any possible workaround? I've read around different threads mentioning scripts for LEDs (for different FW/models), but I do not really understand those (especially for the button pressed event) and I do not see how to adapt to my needs.
OK, it can be done with the front button. There is a Buttons/LED entry in the administration and this is where the scripts can be entered. But I have a message saying that this functionality is not available in this build.
Is it due to the router model, or should it be available in the AIO build?
