QOS crashing wndr3500l with vpnkong 19545M and 20805M
4 posts / 0 new
Suprazz
When I enable QOS in my router, after few hours the router crash and I need to reboot it. I'm still connected to the wifi but I can access the webpage and I dont have an internet access. Any idea why it does that?
Samuel
Suprazz
problem also happen with an
problem also happen with an other router (wndr3500l)
Is there something special I need to do. I'll try to do a syslog and to see what is happening
Suprazz
just noticed that: there is a
just noticed that: there is a lot of WLAN daemon hanging, send SIGKILL
Apr 5 08:09:10 netgear user.info syslog: vpn modules : vpn modules successfully unloaded
Apr 5 08:09:10 netgear user.info syslog: vpn modules : nf_conntrack_proto_gre successfully loaded
Apr 5 08:09:10 netgear user.info syslog: vpn modules : nf_nat_proto_gre successfully loaded
Apr 5 08:09:10 netgear user.info syslog: vpn modules : nf_conntrack_pptp successfully loaded
Apr 5 08:09:10 netgear user.info syslog: vpn modules : nf_nat_pptp successfully loaded
Apr 5 08:09:11 netgear user.info kernel: IMQ driver unloaded successfully.
Apr 5 08:09:12 netgear user.info syslog: wland : WLAN daemon hanging, send SIGKILL
Apr 5 08:09:12 netgear user.info syslog: wland : WLAN daemon successfully stopped
Apr 5 08:09:12 netgear user.info syslog: vpn modules : vpn modules successfully unloaded
Apr 5 08:09:12 netgear user.info syslog: vpn modules : nf_conntrack_proto_gre successfully loaded
Apr 5 08:09:12 netgear user.info syslog: vpn modules : nf_nat_proto_gre successfully loaded
Apr 5 08:09:12 netgear user.info syslog: vpn modules : nf_conntrack_pptp successfully loaded
Apr 5 08:09:12 netgear user.info syslog: vpn modules : nf_nat_pptp successfully loaded
Apr 5 08:09:12 netgear user.info kernel: IMQ starting with 2 devices...
Apr 5 08:09:12 netgear user.info kernel: IMQ driver loaded successfully.
Apr 5 08:09:12 netgear user.info kernel: Hooking IMQ before NAT on PREROUTING.
Apr 5 08:09:12 netgear user.info kernel: Hooking IMQ after NAT on POSTROUTING.
Apr 5 08:09:14 netgear user.info syslog: wland : WLAN daemon hanging, send SIGKILL
Apr 5 08:09:14 netgear user.info syslog: wland : WLAN daemon successfully started
Czarnodziej
Did you manage to fix this
Did you manage to fix this issue? I have the same problem on WNR3500L V1 and 21661M with QoS enabled :/
