New Kong Build: 21375
9 posts / 0 new
buddee
Looks like Kong was kind enough to roll a build for testing, please do so and report within this thread, thank you. Some of the new things in this build are:
 build with new toolchain gcc4.7 linaro uClibc0.9.33.2
 new ftp/samba user management
 lib3g
 bird
 olsrd 0.6.5.2
 openvpn 2.3.1
 proftpd 1.3.4c
 samba 3.6.12
http://www.desipro.de/ddwrt/r21375/
gambitmac
USB mounting is not working
USB mounting is not working correctly.
It mounts to /mnt previous build mounted to /tmp/mnt/disc0-part3
Kong
Hi gambitmac, can you show me
Hi gambitmac, can you show me the output from Disk Info?
gambitmac
Kong said: Hi gambitmac, can
Kong said: Hi gambitmac, can you show me the output from Disk Info?
Disk Info
Disk 0:
Block device, size 7.455 GiB (8004304896 bytes)
DOS/MBR partition map
Partition 1: 1.003 GiB (1077479424 bytes, 2104452 sectors from 63)
Type 0x83 (Linux)
Ext2 file system
Volume name "Optware"
UUID F39E539A-1C8A-4DDC-96DF-3F03D6B4BCC0 (DCE, v4)
Volume size 1.003 GiB (1077477376 bytes, 263056 blocks of 4 KiB)
Partition 2: 62.75 MiB (65802240 bytes, 128520 sectors from 2104515)
Type 0x82 (Linux swap / Solaris)
Linux swap, version 2, subversion 1, 4 KiB pages, little-endian
Swap size 62.75 MiB (65794048 bytes, 16063 pages of 4 KiB)
Partition 3: 6.389 GiB (6859883520 bytes, 13398210 sectors from 2233035)
Type 0x83 (Linux)
Ext2 file system
Volume name "Data"
UUID 160C463F-BDB2-448C-A517-BD2939CB4BC5 (DCE, v4)
Volume size 6.389 GiB (6859882496 bytes, 1674776 blocks of 4 KiB)
Mountpoints:
/dev/scsi/host0/bus0/target0/lun0/part1 mounted to /opt
/dev/scsi/host0/bus0/target0/lun0/part2 mounted to swap
/dev/scsi/host0/bus0/target0/lun0/part3 mounted to /mnt
Kong
Hi gambitmac,
Hi gambitmac,
what is the output of:
nvram show | grep usb_mnt
I actually did not change anything in my mount code, so this change either comes from some dd-wrt update, which I doubt or from some optware script. I have the same partitioning and it works fine here.
Devaster
by me the mount points are ok
by me the mount points are ok, but SSH acces is diabled and the settings are grayed ...
Kong
@Devaster, check your
@Devaster, check your settings under Services->Services and Administration-> Management.
SSH is one of the things you can be sure is always working:-)
Before I upload a build I flash and test things that I need for daily business, to be specific:
DDNS
PPPOE
SSH
Webinterface
DHCP
Wireless
Samba
gambitmac
Kong said: Hi gambitmac, what is the output of: nvram show | grep usb_mnt I actually did not change anything in my mount code, so this change either comes from some dd-wrt update, which I doubt or from some optware script. I have the same partitioning and it works fine here.
Sorry for the delay in getten back with you Kong, had to revert back to r20805 for this week, will update to r21395 this weekend, could'nt have the network now for testing this build like i though i could..  Will load r21395 and report back with any finding.
gambitmac
This is on build 21395
root@Low Brass E3000 - 1:~# nvram show | grep usb_mnt
size: 30920 bytes (30520 left)
usb_mntpoint=opt
usb_mntopt=
usb_mntmnt=
usb_mntjffs=
Disk Info Disk 0:
Block device, size 298.1 GiB (320044269568 bytes)
Type 0x83 (Linux)
Ext2 file system
UUID EC7C2D64-A63C-46D7-8C4A-673ED685D681 (DCE, v4)
Partition 3: 247.0 GiB (265215928320 bytes, 517999860 sectors from 2233035)
Type 0x83 (Linux)
Ext2 file system
Volume name "Data-1"
UUID D273624B-A20F-42DF-877B-8E07C2C64DB8 (DCE, v4)
Volume size 247 GiB (265214230528 bytes, 64749568 blocks of 4 KiB)
Partition 4: 49.99 GiB (53678177280 bytes, 104840190 sectors from 520232895)
Type 0x83 (Linux)
Ext2 file system
Volume name "Data-2"
UUID 9FE86DE5-81DE-45B1-9D0B-B55C3013361C (DCE, v4)
Volume size 49.99 GiB (53678174208 bytes, 13105023 blocks of 4 KiB)
Mountpoints:
/dev/scsi/host0/bus0/target0/lun0/part3 mounted to /tmp/mnt/disc0-part3
/dev/scsi/host0/bus0/target0/lun0/part4 mounted to /tmp/mnt/disc0-part4
SAMBA will not allow me to chose /tmp/mnt/disc0-part3 or /tmp/mnt/disc0-part4 it only allows me to chose /mnt/disc0-part3 or /mnt/disc0-part4 and those dont have any of my files.
Optware automout is turned off. "also removed optware still unable to mount correctly"
update: after a little more digging I think i have found the problem /tmp/smb.conf is blank, attempt to create the file after reboot it was blank again.
