<Solved> Broken Tagged VLAN
4 posts / 0 new
mac913
Does anyone has any of the newer Kong builds 2XXX working with Tagged VLAN?
I am using VPN Build 20575M and Tagged VLAN does not work with my smart switch, which supports 802.1Q Tagging.
I tried via the GUI and the DDWRT Switched Ports Wiki guide with no luck.
TIA!!
buddee
First off, which router did
First off, which router did you say you were trying to set this up with? Not all models have tested and known to support VLANs, especially newer units.
mac913
I'm using E3000s and E2000s.
I'm using E3000s and E2000s. If it works, what it the recommended method for setting up VLAN Tagging?
TIA!!
mac913
I double checked my scripts
I double checked my scripts and found an error in the Additional DNSMasq Options.
Using VPNKong Build 20575 with Tagged VLAN from GUI setup is now working with the 802.1q Tagged VLAN 8-port smart switch.
