Multiple startup scripts?
3 posts / 0 new
GorbyRulez
I've been told by HMA! vpn service that I need to roll back DD-WRT to an antiquated 14896 build in order for their custom OpenVPN script to run and work properly.  I'm wiling to do that (if necessary) but do not know enough about Linux to be able to ensure that both that script plus my IPv6 script will both run @ startup.  So I guess I've got 3 questions:1) Do I really need to undo my current router config and 30-30-30 back to the old version to get OpenVPN working?2) If I do can I run both scripts simultaneously or sequentially?3) Where can I find a Kong mod build that old?I really wasn't looking forward to redoing all router settings (port forwards, etc...)
Kong
Although I would not really
Although I would not really recommend to use an old build, since there have been a couple of security fixes since, you can just flash:
http://desipro.de/ddwrt/r15000/
You should be able to switch between the old and new build without a reset.
The better option would be to use one of the newest builds and setup openvpn through the gui. The openvpn support in the last two builds is pretty good and there are not really any bug reports concerning vpn.
GorbyRulez
Thanks - I looked at setting
Thanks - I looked at setting it up that way but found the settings very confusing. I'd rather go that route so I'll give it another shot.
