I'm new to all of this, so i suspect i have done something wrong, but here it goes.
Just got my wnr3500Lv2 today, and wanted to install ddwrt on it.
followed the instructions and installed the new firmware.
progress bar seemed to be fine and my router restarted.
After this i am unable to access web setup through the normal ip.
Realised after this was done that the ethernet cable wasn't fully connected, and that i had installed it through my wifi, and i suspect this made it a problem, but i am not sure.
The lights and all seem normal and i can connect to it's network, but that's it.
What can i do now? Do i have to go through the de-brick procedure?
Solved, only had to do a standard hard reset
