Hello to all,
today I got my Netgear WNR3500L v2 from Amazon. I flashed it with the latest Tomato Firmware 1.28.0000 MIPSR2-111 K26 USB AIO.
I can acess the router with webinterface but the wifi hardware trigger to turn off wlan seems to be out of function? Is this a known bug. What can I do?
Thanks a lot
Netgear WNR3500LV2 wifi trigger
Sat, 08/17/2013 - 8:29am
#1
Use the web UI to disable / turn off your wi-fi.
These open source softwares are designed to run on more than one router, so may not have code necessary to see a particular 'button' on the physical device.
