Can anyone confirm if any of the Kingkong versions are compatible with the Linksys 1550
Yes they are, and any other nv60k kong builds are compatible as well. Just have to make sure to use the nv60k flavors. Also if you are still on stock firmware with it, you'll first have to flash it with an official dd-wrt trailed e1550 build first, such as this:
ftp://ftp.dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/2013/05-27-2013-r...
Then 30-30-30 and power cycle (required for this unit) and then you can upgrade to any of the kong nv60k flavors.
Thanks I already have the mega version running the routers.
