New Build 20500 (Kong)
76 posts / 0 new
scottl523
scottl523's picture
I've flashed with the 20575
I've flashed with the 20575 usb-ftp-samba3-vpn-nv60k-broadcom build. I'm still trying to setup a media server I followed the instructions on this link http://tips.desipro.de/2011/08/25/komg-mod-dlna-media-server-setup/
I'm not seeing a UUID in the disk info.
Disk 0:
Block device, size 1.819 TiB (2000398934016 bytes)
DOS/MBR partition map
Partition 1: 1.819 TiB (2000396289024 bytes, 3907024002 sectors from 63)
Type 0x07 (HPFS/NTFS)
NTFS file system
Volume size 1.819 TiB (2000396288512 bytes, 3907024001 sectors)
Mountpoints:
/dev/scsi/host0/bus0/target0/lun0/part1 mounted to /tmp/mnt/disc0-part1
BlaSTiWi
BlaSTiWi's picture
scottl523 said: I've flashed
scottl523 said: I've flashed with the 20575 usb-ftp-samba3-vpn-nv60k-broadcom build. I'm still trying to setup a media server I followed the instructions on this link http://tips.desipro.de/2011/08/25/komg-mod-dlna-media-server-setup/ I'm not seeing a UUID in the disk info. Disk 0: --- /dev/scsi/host0/bus0/target0/lun0/disc Block device, size 1.819 TiB (2000398934016 bytes) DOS/MBR partition map Partition 1: 1.819 TiB (2000396289024 bytes, 3907024002 sectors from 63) Type 0x07 (HPFS/NTFS) NTFS file system Volume size 1.819 TiB (2000396288512 bytes, 3907024001 sectors) Mountpoints: /dev/scsi/host0/bus0/target0/lun0/part1 mounted to /tmp/mnt/disc0-part1
Chk and see the guide again carefully ... if you notice pic #1 in the guide the partition being mounted is Linux Ext2 partition hence it has UUID your partition on the other hand is NFTS.
Aside from the UUID your disk is mounted no problem under /tmp/mnt/disc0-part1.
Kong
Kong's picture
If there is no uuid and
If there is no uuid and volume name then you cannot specify a specific mountpoint, thus it is mounted to "/tmp/mnt/disc0-part1" which is fine. Just use that path in minidlna setup, e.g. your drive shows up in Windows under D: you create a dir D:\Video which contains your videos, now on your router you specify /tmp/mnt/disc0-part1/Video same for other dirs.
scottl523
scottl523's picture
It says minidlna stopped
It says minidlna stopped under sys info. I have it enabled.
basmaf
basmaf's picture
Zabbix is working great
Zabbix is working great thanks!
I used the optware version which resulted in memory problems.
amomp3
amomp3's picture
Hello KONG, I want to say
Hello KONG, I want to say THANK YOU VERY MUCH for sharing your very hard and excellent work with the world. We need more people like this in the world. REALLY THANK YOU.
Piotr.Dobrogost
Piotr.Dobrogost's picture
I flashed my WNR 3500L with
I flashed my WNR 3500L with build 20500M (was using 19545M up until now) and made 30-30-30 reset. After this whenever I click Save button after changing any setting I get connection reset error in the browser. I can't go back to the previous build due to this, either.
Any suggestions?
Kong
Kong's picture
Piotr.Dobrogost said: I
Piotr.Dobrogost said: I flashed my WNR 3500L with build 20500M (was using 19545M up until now) and made 30-30-30 reset. After this whenever I click Save button after changing any setting I get connection reset error in the browser. I can't go back to the previous build due to this, either. Any suggestions?
Try a different browser.
Piotr.Dobrogost
Thanks for help and many
Thanks for help and many thanks for your build.
Funny how I did not think of this; after your advice I tried Chrome instead of Firefox and everything was ok. After rebooting router from within gui one more time it started to work in Firefox as well. It's the first time I witness this behavior. However after another reboot router became unstable - I don't get home page at all or get only some of the resources (no css for exeample). Making 30-30-30 reset again did not help - when I get to load router's home page (one in several attempts) I get password change page but after pressing "Change password" button nothing happens (the text on the button changes to "Changing password" and it's stuck in this state).
Any ideas?
Kong
Kong's picture
Piotr.Dobrogost said: Thanks
Piotr.Dobrogost said: Thanks for help and many thanks for your build. Funny how I did not think of this; after your advice I tried Chrome instead of Firefox and everything was ok. After rebooting router from within gui one more time it started to work in Firefox as well. It's the first time I witness this behavior. However after another reboot router became unstable - I don't get home page at all or get only some of the resources (no css for exeample). Making 30-30-30 reset again did not help - when I get to load router's home page (one in several attempts) I get password change page but after pressing "Change password" button nothing happens (the text on the button changes to "Changing password" and it's stuck in this state). Any ideas?
Firefox NoScript installed or some firewall suite like Kaspersky?
Piotr.Dobrogost
Kong said: Firefox NoScript installed or some firewall suite like Kaspersky?
Not really. Also I get the same behavior in both Firefox and Chrome. The only thing that changed is the firmware - no changes were made in the system. It looks like the problem is on the router's side.
Kong
Kong's picture
I have only experienced this if NoScript is installed and scripts are not allowed, then the gui looks garbled. Other than that I haven't seen this and never got a report that this happened. Did you try via wire and wireless maybe network issue?
Piotr.Dobrogost
When trying to connect to
When trying to connect to router through SSH I got an error about insufficient buffer space which I saw for the first time and I took it to mean something is wrong with my system. After rebooting computer there's no problem with connection to the router using web interface. Now, there's another problem which unlike the previous ones is familiar. Although there's established PPPoE connection and I see valid WAN IP and DNS IPs the connection is dead - pinging these DNS servers does not work. From what I know this could be due to wrong MTU setting but again, it was set to automatic like with the previous firmware which was working fine.
What should I check now? Also, where can I find latest DD-WRT for this router? I see people talking about rev 22200 but I don't know where to find it.
ps.
I know all this looks very weird and like very unstable environment but I've been working with previous firmware for over a year without any problems...
Piotr.Dobrogost
I've checked router in
I've checked router in another place and everything is ok so this must be something else.
Kong, thanks a lot for your help.
Myname
Myname's picture
Guys, I have set a 1GB LAN
Guys, I have set a 1GB LAN home, connecting my laptop (wired) via E3200 router with 20500M King Kong to my LAN network player with HDD. But the maximu speed I can reach is 10-11 MB/sec - wired laptop and 4-5 MB/sec wireless laptop... Both - laptop and player has 1GB LAN card. Is there any way to increase the speed?
