I have a Netgear r6300 v1. I have managed to install DDT-WRT v24-sp2 (10/18/12) mega on to it.
I want to upgrade to a firmware which utilises Openvpn. but everytim I try to upgrade, i get an upgrade failed message.
I cant understand what I am doing wrong.
I am trying to install dd-wrt.v24-21676_NEWD-2K3.x_mega-R6300.bin.
Any help would be really gratefully received.
regards
Marc
You have to install DD-WRT Initial flash first then you can upload the .bin file.
While Tathagata's build needs to update only one .chk file.
Both firmwares support OpenVPN.
