Has anyone been able to get a Samba share working on this build? I am certain I have it set up correctly, however when I try to access \\Dd-wrt\ on my Windows machine it will not connect.
First try with \\ip\ if that works you can try \\routername\
routername is the one you set on Setup->Basic Setup->Router Name
Thanks Kong... I was able to get to it using the ip. Not sure why the router name is not working. I have that set as the default DD-WRT.
Did you try after a router reboot?
Yes, I've rebooted multiple times and also tried a 30-30-30 reset. I am okay with accessing using the IP address... its just odd that the router name doesn't work.
Can you login to the router and run command:
ps | grep smb
It should display:
10552 root 2512 S /usr/sbin/smbd -D --configfile=/tmp/smb.conf
10554 root 2320 S /usr/sbin/nmbd -D --configfile=/tmp/smb.conf
if there is no nmbd service running for whatever reason, then we know the cause, if it is running, then your client computer has a problem with its firewall.
Yeah the service is running:
root@DD-WRT:~# ps | grep smb
19161 root 2492 S /usr/sbin/smbd -D --configfile=/tmp/smb.conf
19169 root 2308 S /usr/sbin/nmbd -D --configfile=/tmp/smb.conf
Its strange because it showed up before. Guess I have some more digging to do :) Thanks for your help Kong!
hello, newbie question i am having an issue where i actually can see the drive and folder but cannot access it.
Network Error
[Main Instruction]
Windows cannot access \\NETGEAR R7000\Data
[Content]
Check the spelling of the name. Otherwise, there might be a problem with your network. To try to identify and resolve network problems, click Diagnose.
[^] Hide details [Diagnose] [Cancel]
[Expanded Information]
Error code: 0x80070035
The network path was not found.
please advise...thx
If the folder shows up in explorer, then samba is working correctly, but samba cannot access the drive. This means, there is a problem with either mounting or with usb access. You can try to login via telnet or ssh and run each of the following command:
mount
dmesg
and show us the output.
DD-WRT v24-sp2 kongac (c) 2014 NewMedia-NET GmbH
Release: 01/27/14 (SVN revision: 23430M)
Netgear R7000 login: root
Password:
____ ___ __ ______ _____ ____ _ _
| _ \| _ \ \ \ / / _ \_ _| __ _|___ \| || |
|| | || ||____\ \ /\ / /| |_) || | \ \ / / __) | || |_
||_| ||_||_____\ V V / | _ |___/|___/ \_/\_/ |_| \_\|_| \_/ |_____| |_|
DD-WRT v24-sp2
http://www.dd-wrt.com
BusyBox v1.22.1 (2014-01-27 21:05:34 CET) built-in shell (ash)
root@Netgear R7000:~# mount at 0
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
ramfs on /tmp type ramfs (rw,relatime)
none on /dev type tmpfs (rw,relatime,size=512K)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
devpts on /proc/bus/usb type usbfs (rw,relatime)
/dev/sda1 on /opt type ext3 (rw,relatime,errors=continue,barrier=1,data=writebac k)
/dev/sda3 on /tmp/mnt/sda3 type ext3 (rw,relatime,errors=continue,barrier=1,data =writeback)
root@Netgear R7000:~# dmesg
Booting Linux on physical CPU 0x0
Linux version 3.10.25 ([email protected]) (gcc version 4.7.3 20121205 (prerelease) (Linaro GCC 4.7-2012.12) ) #411 SMP PREEMPT Mon Jan 27 21:07:01 CET 2014
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Northstar Prototype
Ignoring unrecognised tag 0x00000000
Memory policy: ECC disabled, Data cache writealloc
map io
MPCORE found at 19020000 (VIRT d9020000) 18000000 d8000000
On node 0 totalpages: 65536
free_area_init_node: node 0, pgdat c035a680, node_mem_map c03dd000
Normal zone: 256 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 32768 pages, LIFO batch:7
HighMem zone: 4352 pages used for memmap
HighMem zone: 32768 pages, LIFO batch:7
PERCPU: Embedded 7 pages/cpu @c15ec000 s7232 r8192 d13248 u32768
pcpu-alloc: s7232 r8192 d13248 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65280
Kernel command line: console=ttyS0,115200 panic=10 root=/dev/mtdblock3 earlyprintk=1 rootfstype=squashfs,jffs2 noinitrd init=/bin/sh
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 255908k/255908k available, 6236k reserved, 131072K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0309ddc (3080 kB)
.init : 0xc030a000 - 0xc033fc40 ( 216 kB)
.data : 0xc0340000 - 0xc037c6fc ( 242 kB)
.bss : 0xc037c6fc - 0xc03dcd98 ( 386 kB)
Preemptible hierarchical RCU implementation.
CONFIG_RCU_FANOUT set to non-default value of 2
NR_IRQS:256
MPCORE GIC init
External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
MPCORE Global Timer Clock 500000000Hz on IRQ 27
sched_clock: 32 bits at 500MHz, resolution 2ns, wraps every 8589ms
register local timer
smp_twd: clock not found -2
Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
pid_max: default: 32768 minimum: 301
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Calibrating local timer... 499.73MHz.
2 cores has been found
Setting up static identity map for 0xc00127c8 - 0xc00127fc
L310: cache controller enabled 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x7a130000
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3981.31 BogoMIPS).
DMA: preallocated 256 KiB pool for atomic coherent allocations
Found a Samsung NAND flash:
Total size: 128MB
Block size: 128KB
Page Size: 2048B
OOB Size: 64B
Sector size: 512B
Spare size: 16B
ECC level: 8 (8-bit)
Device ID: 0xec 0xf1 0x 0 0x95 0x40 0xec
found nand nvram at 80000
CCA UART Clock Config: Sel=1 Ovr=1 Div=48
CCA UART Clock rate 125000000Hz
bio: create slab
Switching to clocksource mpcore_gtimer
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
PCI: CLS 0 bytes, default 64
init gpio code
Netgear R7000 init
PCI: no core
PCI: no core
PCI: scanning bus 0
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0xffffffff]
pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:00.0: [14e4:0800] type 00 class 0x050100
pci 0000:00:00.0: reg 10: [mem 0x18000000-0x18000fff]
pci 0000:00:00.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:01.0: [14e4:050b] type 00 class 0xffffff
pci 0000:00:01.0: reg 10: [mem 0x18001000-0x18001fff]
pci 0000:00:01.0: reg 14: [mem 0x18002000-0x18002fff]
pci 0000:00:01.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:02.0: [14e4:0502] type 00 class 0xffffff
pci 0000:00:02.0: reg 10: [mem 0x1802c000-0x1802cfff]
pci 0000:00:02.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:03.0: [14e4:4715] type 00 class 0x020000
pci 0000:00:03.0: reg 10: [mem 0x18024000-0x18024fff]
pci 0000:00:03.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:04.0: [14e4:4715] type 00 class 0x020000
pci 0000:00:04.0: reg 10: [mem 0x18025000-0x18025fff]
pci 0000:00:04.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:05.0: [14e4:4715] type 00 class 0x020000
pci 0000:00:05.0: reg 10: [mem 0x18026000-0x18026fff]
pci 0000:00:05.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:06.0: [14e4:4715] type 00 class 0x020000
pci 0000:00:06.0: reg 10: [mem 0x18027000-0x18027fff]
pci 0000:00:06.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:07.0: [14e4:0501] type 00 class 0xffffff
pci 0000:00:07.0: reg 10: [mem 0x18012000-0x18012fff]
pci 0000:00:07.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:08.0: [14e4:0501] type 00 class 0xffffff
pci 0000:00:08.0: reg 10: [mem 0x18013000-0x18013fff]
pci 0000:00:08.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:09.0: [14e4:0501] type 00 class 0xffffff
pci 0000:00:09.0: reg 10: [mem 0x18014000-0x18014fff]
pci 0000:00:09.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0a.0: [14e4:0510] type 00 class 0xffffff
pci 0000:00:0a.0: reg 10: [mem 0x1800b000-0x1800bfff]
pci 0000:00:0a.0: reg 14: [mem 0x1800c000-0x1800cfff]
pci 0000:00:0a.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0b.0: [14e4:471a] type 00 class 0x0c0310
pci 0000:00:0b.0: reg 10: [mem 0x18022000-0x18022fff]
pci 0000:00:0b.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0b.1: [14e4:471a] type 00 class 0x0c0320
pci 0000:00:0b.1: reg 10: [mem 0x18021000-0x18021fff]
pci 0000:00:0b.1: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0c.0: [14e4:472a] type 00 class 0x0c0330
pci 0000:00:0c.0: reg 10: [mem 0x18023000-0x18023fff]
pci 0000:00:0c.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0d.0: [14e4:0503] type 00 class 0xffffff
pci 0000:00:0d.0: reg 10: [mem 0x18020000-0x18020fff]
pci 0000:00:0d.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0e.0: [14e4:4711] type 00 class 0x040100
pci 0000:00:0e.0: reg 10: [mem 0x1802a000-0x1802afff]
pci 0000:00:0e.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:0f.0: [14e4:0506] type 00 class 0xffffff
pci 0000:00:0f.0: reg 10: [mem 0x18210000-0x1821ffff]
pci 0000:00:0f.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:10.0: [14e4:0507] type 00 class 0xffffff
pci 0000:00:10.0: reg 10: [mem 0x18010000-0x18010fff]
pci 0000:00:10.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:11.0: [14e4:0508] type 00 class 0xffffff
pci 0000:00:11.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:12.0: [14e4:0509] type 00 class 0xffffff
pci 0000:00:12.0: reg 10: [mem 0x18028000-0x18028fff]
pci 0000:00:12.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:00:13.0: [14e4:050a] type 00 class 0xffffff
pci 0000:00:13.0: reg 10: [mem 0x18029000-0x18029fff]
pci 0000:00:13.0: reg 30: [mem 0x00000000-0x000007ff pref]
PCI: Fixing up bus 0
PCIE1 link=1
PCIE1 switching to GEN2
PCIE1 link=1
PCI host bridge to bus 0001:00
pci_bus 0001:00: root bus resource [mem 0x08000000-0x0fffffff]
pci_bus 0001:00: No busn resource found for root bus, will use [bus 00-ff]
pci 0001:00:00.0: [14e4:8012] type 01 class 0x060400
pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
PCI: bus0: Fast back to back transfers disabled
pci 0001:01:00.0: [14e4:4360] type 00 class 0x028000
pci 0001:01:00.0: reg 10: [mem 0x08000000-0x08007fff 64bit]
pci 0001:01:00.0: supports D1 D2
PCI: Fixing up bus 1
PCI: bus1: Fast back to back transfers disabled
pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
pci_bus 0001:00: busn_res: [bus 00-ff] end is updated to 01
pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
pci 0001:00:00.0: PCI bridge to [bus 01]
pci 0001:00:00.0: bridge window [mem 0x08000000-0x080fffff]
PCIE2 link=1
PCIE2 switching to GEN2
PCIE2 link=1
PCI host bridge to bus 0002:00
pci_bus 0002:00: root bus resource [mem 0x40000000-0x47ffffff]
pci_bus 0002:00: No busn resource found for root bus, will use [bus 00-ff]
pci 0002:00:00.0: [14e4:8012] type 01 class 0x060400
pci 0002:00:00.0: PME# supported from D0 D3hot D3cold
pci 0002:02:00.0: [14e4:4360] type 00 class 0x028000
pci 0002:02:00.0: reg 10: [mem 0x40000000-0x40007fff 64bit]
pci 0002:02:00.0: supports D1 D2
PCI: Fixing up bus 2
PCI: bus2: Fast back to back transfers disabled
pci_bus 0002:02: busn_res: [bus 02-ff] end is updated to 02
pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to 02
pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
pci 0002:00:00.0: PCI bridge to [bus 02]
pci 0002:00:00.0: bridge window [mem 0x40000000-0x400fffff]
PCIE3 link=0
Error creating gpio class
msgmni has been set to 243
alg: No test for stdrng (krng)
io scheduler noop registered (default)
io scheduler cfq registered
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x18000300 (irq = 117) is a 16550
console [ttyS0] enabled
brd: module loaded
loop: module loaded
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x200000, 0x20000
found TRX Header on nflash!
nflash: squash filesystem with lzma found at block 27
0x000000200000-0x000002200000 : "linux"
0x000000360000-0x000002200000 : "rootfs"
0x000002200000-0x000002240000 : "board_data"
tun: (C) 1999-2004 Max Krasnyansky
PPP BSD Compression module registered
PPP Deflate Compression module registered
GACT probability NOT on
Mirror/redirect action on
Failed to load ipt action
u32 classifier
Performance counters on
input device check on
Actions configured
nf_conntrack version 0.5.0 (3998 buckets, 15992 max)
nf_conntrack_rtsp v0.6.21 loading
ip_set: protocol 6
gre: GRE over IPv4 demultiplexor driver
nf_nat_rtsp v0.6.21 loading
TCP: bic registered
TCP: cubic registered
TCP: westwood registered
TCP: highspeed registered
TCP: hybla registered
TCP: htcp registered
TCP: vegas registered
TCP: veno registered
TCP: scalable registered
TCP: lp registered
TCP: yeah registered
TCP: illinois registered
Bridge firewalling registered
8021q: 802.1Q VLAN Support v1.8
Key type encrypted registered
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0)
Driver must set ecc.strength when using hardware ECC
Bad eraseblock 25 at 0x000000320000
Bad eraseblock 702 at 0x0000057c0000
Options: CACHEPRG,NO_SUBPAGE_WRITE,
0x000002240000-0x000008000000 : "ddwrt"
Freeing unused kernel memory: 212K (c030a000 - c033f000)
softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=1)
et: module license 'Proprietary' taints kernel.
et_module_init: txworkq set to 0x1
et_module_init: et_txq_thresh set to 0x400
et0: online cpus 2
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.62 (r437318)
roboswitch: Probing device 'eth0'
roboswitch: trying a 53012! at eth0
roboswitch: found a 53012! at eth0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-pci 0000:00:0b.1: EHCI Host Controller
ehci-pci 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci-pci 0000:00:0b.1: irq 111, io mem 0x18021000
ehci-pci 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 4
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
SCSI subsystem initialized
eth0: mixed HW and IP checksum settings.
jffs2: version 2.2. (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_SIZE) © 2001-2006 Red Hat, Inc.
device br0 entered promiscuous mode
device vlan1 entered promiscuous mode
device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
device eth2 entered promiscuous mode
br0: port 3(eth2) entered forwarding state
br0: port 2(eth1) entered forwarding state
br0: port 1(vlan1) entered forwarding state
device br0 left promiscuous mode
device vlan2 entered promiscuous mode
device vlan2 left promiscuous mode
usb 1-2: new high-speed USB device number 2 using ehci-pci
usb-storage 1-2:1.0: USB Mass Storage device detected
scsi0 : usb-storage 1-2:1.0
scsi 0:0:0:0: Direct-Access WD Ext HDD 1021 2002 PQ: 0 ANSI: 4
sd 0:0:0:0: [sda] 3907024896 512-byte logical blocks: (2.00 TB/1.81 TiB)
sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
sd 0:0:0:0: [sda] Asking for cache data failed
sda: sda1 sda2 sda3
Adding 1048572k swap on /dev/sda2. Priority:-1 extents:1 across:1048572k
kjournald starting. Commit interval 5 seconds
EXT3-fs (sda1): using internal journal
EXT3-fs (sda1): recovery complete
EXT3-fs (sda1): mounted filesystem with writeback data mode
EXT3-fs (sda3): using internal journal
EXT3-fs (sda3): recovery complete
EXT3-fs (sda3): mounted filesystem with writeback data mode
nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
device vlan1 left promiscuous mode
device eth0 left promiscuous mode
br0: port 1(vlan1) entered disabled state
device eth1 left promiscuous mode
br0: port 2(eth1) entered disabled state
device eth2 left promiscuous mode
br0: port 3(eth2) entered disabled state
thanks for the help...here is the output...
Mounting looks good, it looks like you are not using the correct name to resolve the router. Are you sure "NETGEAR R7000" is "Router Name" as configure under Setup->Basic Setup->Optional Settings
yes that is correct...windows can see the router and shared folder but cannot access it, tried to access it via my android device as well same thing...can see it but no access...tried both checking public access a creating a user with password access...
Deleted subdir path and recreated the folder, i can access the drive now...thx for the assist much appreciated.
hello, nice work with the config. However i'm wondering if it is possible to alter the extra samba settings. I want to make my router local master and able to change the os level. So it can manage all, and i can see the complete network neigbourhood
thank you
Yes there is a hack that allows it. You just have to login via ssh, then run command:
nvram set samba3_conf='contents of a custom smb.conf'
nvram set samba3_advanced=1
nvram commit
reboot
after that sambaservice will use the text you save in samba3_conf to create the /tmp/smb.conf and start with this config.
hello,
thank you for your reply
what do you mean with contents of a custom smb
i want to include these 3 lines
local master = yes
prefered master = yes
os level = 255
how do i have to specify this?
