Everytime I try to download the 23430 King build for my R7000 from the "Download Now!" link using IE11, I'm not prompted to save the file and IE attempts to open the page, resulting in a bunch of crazy characters. How do I download it?
tyia
-pth
tyia
-pth
I had this issue with win8 and switch to desktop mode. Then I used chrome or explorer and it worked. You might just try to switch browser.
It may be the browser cache problem. Anyways, good to know that things are working at your end.
Try to download from the directory, just use the file in the 23430 folder. Right click and save the file.
Thank-You...very helpful
