Well, I tried posting this on the DD-WRT forum but no luck there so I will try here.
I have this unit running kongac 23550M. I have a thumb drive with 2 partitions. The first is swap, and the second is data. When I choose to automount, the firmware tries to mount the first partition to opt. Using the UUID method it does not work. Is there a way to use the UUID method without having automount on?
What's the output of Disk Info.
--- /dev/sda
Block device, size 3.749 GiB (4025810432 bytes)
DOS/MBR partition map
Partition 1: 130 MiB (136314880 bytes, 266240 sectors from 2048)
Type 0x82 (Linux swap / Solaris)
Linux swap, version 2, subversion 1, 4 KiB pages, little-endian
Swap size 130.0 MiB (136306688 bytes, 33278 pages of 4 KiB)
Partition 2: 3.621 GiB (3888119808 bytes, 7593984 sectors from 268288)
Type 0x83 (Linux)
Ext3 file system
Volume name "SD2GB"
UUID D9E895C8-3E3E-434A-846E-EE8345A5A82F (DCE, v4)
Volume size 3.621 GiB (3888119808 bytes, 949248 blocks of 4 KiB)
Ext3 file system
Volume name "opt"
UUID 20190408-4CBA-9703-4806-010293EEE500 (NCS)
Volume size 3.749 GiB (4025809920 bytes, 3931455 blocks of 1 KiB)
/dev/sda mounted to /opt
--- /dev/sda1
Block device, size 130 MiB (136314880 bytes)
/dev/sda1 mounted to swap
--- /dev/sda2
Block device, size 3.621 GiB (3888119808 bytes)
Ext3 file system
Volume name "SD2GB"
/dev/sda2 mounted to /tmp/mnt/sda2
Well crap, just tryed it again. It doesn't work if when you click apply. After rebooting it does mount using the UUID.
Shouldn't the usb Service restart when you click appy?
Disk Info --- /dev/sda
Type 0x83 (Linux)
Ext3 file system
Volume name "SD2GB"
Ext3 file system
Volume name "opt"
--- /dev/sda1
--- /dev/sda2
Ext3 file system
Volume name "SD2GB"
/dev/sda2 mounted to /opt
