Instantly share any public Internet connection and stay secure with firewall protection for public hotspots with NETGEAR Trek™ Travel Router and Range Extender. With a powerful flip-out antenna, you’ll enjoy increased range whether you use it on the go, or at home. This compact device can be used as a router, range extender, access point or bridge to keep you connected wherever you trek.
- Extend your existing Wi-Fi coverage throughout your home
- Eliminate Wi-Fi dead zones in hard to reach areas
- Create a private Wi-Fi network with firewall protection on public hotspots
- No longer pay multiple access fees for each device
- High-performance flip-out antenna
- Boost the Signal of Weak Public Wi-Fi Hotspots
- Convenient USB power options for use with laptops or wall-plug design
- NETGEAR genie App-Dashboard to monitor, control & repair your network
NETGEAR genie App
- Easily manage, monitor & repair your network
- Makes any printer AirPrint compatible to print from an iPad or iPhone
- MyMedia—Find & play media files in your network
- For PC, Mac, iPhone, iPad, & Android devices
WiFi Band
- 2.4 GHz
Number of Ethernet Ports
- Two (2) 10/100 Mbps (1 Internet/LAN and 1 LAN) Ethernet ports with auto-sensing technology
Key Features
- Multipurpose WiFi device: WiFi router, WiFi access point, Hotspot and Range extender
- N300 WiFi (802.11 b/g/n)
- Palm-size for easy portability
- Flip-out antenna for optimal WiFi coverage
- Charge mobile phone via USB when wall-plugged
- Micro USB powered for better mobility
- Intelligence to detect between network modes
- READYSHARE® USB—Wirelessly share and access USB storage
Security
- WiFi Protected Access® (WPA/WPA2—PSK) and WEP
- Software WPS PIN and PBC (Push Button Configuration) modes
- Double firewall protection (SPI and NAT firewall)
- Denial-of-service (DoS) attack prevention
- DMZ for secure gaming
Physical Specifications
- Dimensions: 3.39 x 3.31 x 1.30 in (86.5 mm x 86.2 mm x 32 mm)
- Net Weight: 0.355 lb (161 g)
Can you use this to share a WIFI link between 2 tablet/ipads?
Eg In hotels/ motels the user can often only link one device to the WIFI service at a time.
Can this device enable
