Hello everyone,
i wanted to know, if said router can deal with an Annex J type Internet ( https://en.wikipedia.org/wiki/G.992.3_Annex_J )
Furthermore: If my ISP will change their service to Annex J, does my router need to adapt on a hardware basis, or can this be done with a change on software/firmware level?
Anyway, I'm happy to have found this site. When I'll need a new router, the WNR3500L seems like THE way to go.
Great,
regards,
Martin
anyone ..?
The WNR3500L / WNR3500L v2 are wireless routers, not DSL modems. there, as that's up to your
No need to worry about Annex
DSL-modem to figure out/support.
Were you actually thinking of a DGN3500, wich -is- a DSL-modem..?
afaik is a modem part of any router (?).
I never used a dedicated modem.
enwiki/dsl-modem:
"The more common DSL router which combines the function of a DSL modem and a home router, is a standalone device which can be connected to multiple computers through multiple Ethernet ports or an integral wireless access point. "
Does this not apply to the WNR3500L?
The WNR3500 / WNR3500L is NOT a modem, but a plain (and nice) wireless router.
Then there is DSL-modems, and Cable-modems. They can have a router-function, or be a plain bridge.
If they also have a router-function, then they are called DSL-router, Cable-router...
Nowhere does the WNR3500 / WNR3500L states to be a modem of any kind.
Oh, and to clarify. You pasted info from Wikipedia, but your search there was for DSL-router.
A quick search for DSL-modem gives:
en-wikipedia-org/wiki/DSL_modem
A digital subscriber line (DSL) modem is a device used to connect a computer or router to a telephone line which provides the digital subscriber line service for connectivity to the Internet, which is often called DSL broadband.
The term DSL modem is technically used to describe a modem which connects to a single computer, through a USB port or is installed in a computer PCI slot.
In my first answer to you I gave a model# which does have DSL-modem and router in one.
As per my knowledge is concerned, WNR3500L is a home router. You have to connect your ISP connection to modem and the modem with your WNR3500L.
