WNR3500l blinking green
4 posts / 0 new
saintjimmy
Hi everyone !
After a failed upgrade to OpenWrt I was unable to access my router so I decided to apply the 30/30/30 method. Now all I got is a black brick with a blinking green light.
I tried to tftp into it and managed to push the official Netgear firmware but I still got the green light blinking.
What does that mean ? What can I do to make my router useable again ?
Thanks for your help
Subhra
Do you have a serial cable??
saintjimmy
Nope, is there any other way ?
Subhra
You may use this Serial Cable
You may use this Serial Cable Connection Hack. Then use this tutorial debrick your router.
