I just installed Kong's DD-WRT firmware installed on my Nighthawk & love it. So much better than the Netgear stock firmware. I do have an issue or question through. The 2.4GHz & 5Ghz Wifi LED lights no longer flash when there is activitiy on the Wifi bands as they should. Is this a bug in the firmware or is there an option somewhere to turn it on? I have searched through all the menu options & don't see an option anywhere.
No this is no default behaviour. Netgear added a hack to the kernel code that makes them flash.
Asour kernel supports multiple units we usually don't implement hacks for a single unit.
Oh I see. Ok thanks Kong for the explaination. So the bottom line is by default those LEDs will not flash unless a hack is applied for a specific unit. Thanks again for all your hard work on the DD-WRT code.
