So I've noticed an issue where my router, even with NTP configured, can't keep the correct date & time. I'll manually set it through the command line, then a reboot later and it thinks it's 1/1/70.
Is this a known issue? Will NTP eventually correct it after a specified period of time?
Nevermind... After some more searching I found the problem was not statically assigning a default gateway. Once I did that NTP started working in between reboots.
