R8000 AC3200 Nighthawk X6 Tri-Band WiFi Router
Announcing the new R8000 AC3200 Nighthawk X6 Tri-Band WiFi Router! Connecting the Internet to Everything
There's never been WiFi like it. The Nighthawk X6 AC3200 Router with breakthrough Tri-Band WiFi technology was built to connect to each and every device in your home??automatically and simultaneously.
Laptops, tablets, phones, TVs, game consoles, music streamers, cameras ?? if it??s WiFi enabled, it??s X6 accelerated.
With a massive combined wireless speed of up to 3.2Gbps, 3 WiFi bands and Smart Connect intelligence, every device is assigned the fastest WiFi connection possible and optimized for maximum speed.
Multiply your WiFi Nighthawk X6 takes your WiFi experience to another level with Tri-Band WiFi and 6 high-performance antennas.
Check out the Video!
More WiFi for More Devices
See the eye-opening, multiple-device-connecting prowess of the Nighthawk X6??with speeds up to 3.2Gbps and a 1 GHz dual core processor with 3 offload processors.
R8000
WiFi Technology
  • 802.11ac Tri-Band Gigabit
Speed and Range
WiFi Performance
  • AC3200 (600 + 1300 + 1300 Mbps)?
WiFi Range
  • Very large homes
WiFi Band
  • Simultaneous Tri-Band WiFi - Tx/Rx 3x3 (2.4GHz) + 3x3 (5GHz) + 3x3 (5GHz)
Beamforming
  • Beamforming+??Smart, signal-focusing technology boosts the speed,reliability, and range of your WiFi connections
Number of Ethernet Ports
  • Five (5) 10/100/1000 (1 WAN and 4 LAN) Gigabit Ethernet ports
Number of USB Ports
  • Two (2) USB ports: 1 USB 3.0 & 1 USB 2.0 port
Key Features
  • AC3200 Tri-Band WiFi
  • WiFi Band 1: 600 Mbps @2.4GHz-256QAM
  • WiFi Band 2: 1300 Mbps @5GHz
  • WiFi Band 3: 1300 Mbps @5GHz
  • Smart Connect intelligently selects the fastest WiFi for every device
  • High powered amplifiers and six (6) high performance external antennas
  • Implicit & Explicit Beamforming for 2.4 & 5GHz
  • Powerful Dual-Core 1GHz processor with 3 offload processors
  • Memory: 128 MB Flash and 256 MB RAM
  • Two (2) USB ports: (1) USB 3.0 & (1) USB 2.0 port
Security
  • Customized free URL to set up personal FTP server
  • VPN support??secure remote access
  • Guest network access??separate & secure
  • WiFi Protected Access® (WPA/WPA2??PSK)
  • Double firewall protection (SPI and NAT)
  • Denial-of-service (DoS) attack prevention
Processor
  • 1GHz dual core porcessor with three offload processors
Processor Technology
Memory
  • 128 MB Flash and 256 MB RAM
Layout
Physical Specifications
  • Dimensions: 11.63 x 8.92 x 2.14 in (295.5 x 226.8 x 54.5 mm)
  • Weight: 2.43 lbs (1.1 kg)
Package Content
  • Nighthawk X6 AC3200 Tri-Band WiFi Router (R8000)
  • Ethernet cable
  • Quick install guide
  • Power adapter
Standards
  • IEEE® 802.11 b/g/n 2.4GHz-256QAM support
  • IEEE® 802.11 a/n/ac 5.0 GHz
System Requirements
  • Microsoft® Windows 7, 8, Vista®, XP®, 2000, Mac OS®, UNIX®, or Linux®
  • Microsoft® Internet Explorer® 5.0, Firefox® 2.0, Safari® 1.4, or Google Chrome? 11.0 browsers or higher
memtek25
What Firmware Would I use on
What Firmware Would I use on this?
