I'm beginner with shell scripting, so maybe I'm missing something very basic...
My script does work perfectly in "tools>system commands", but the "find" command fails in "administration >scheduler"...
Is there any reason why the behavior is different? Environment? Why the" find" only, and not the rest?
The code is directly pasted in the scheduler page...
Here is the full script
if [ -e $runningfile ] ; then
echo already running
# echo already running > $logfile
else
echo 1 > $runningfile
echo "START DOWNLOAD"
echo "START DOWNLOAD" > $logfile
ncftpget -DDRv -u $user -p $pass $logTag $host "$dir_local_tmp" "$dir_remote_source"
if [ "$?" -ne "0" ] ; then
echo "ERROR"
echo "ERROR : $logfile "\n >> $errorlogfile
else
echo "SUCCESS MOVE Result but ignore empty folders"
find "$dir_local_tmp$dir_remote_source" -type d -empty -delete
mv -f "$dir_local_tmp$dir_remote_source" "$dir_local_dest"
fi
rm $runningfile
echo "END"
fi
Well, I have finally made it work.
I added the full path of the command "/opt/bin/find".
Indeed, I understood that the "find" command came with entware like the "ncftpget" ...
But, it's still mysterious, why the "ncftpget" call works and not the "find"...
