Quick Review & Specifications Netgear Dual Band WiFi Range Extender
Maximize the power of your network and make sure you have coverage in every corner of your home with the AC1200 High Power WiFi Range Extender. Get ultimate range and performance you need for iPads®, smartphones, laptops & more!
Product Highlights
  • Extends 802.11ac dual band WiFi up to 1200Mbps
  • 700mW amplified high-power design with 5dBi external antennas for ultimate range
  • Dual core processor for max gigabit WiFi performance
  • Flexible and convenient placement—horizontal or vertical
  • Finds best location for optimal wireless coverage with dynamic LED indicators
  • Easy installation—no CD or Ethernet cable required
  • Provides security through encryption using WPA/WPA2/WEP
Product Benefits
  • Boost WiFi in very large homes and even backyards
  • Eliminate WiFi dead zones in hard to reach areas
  • Improve your mobile WiFi speeds by up to 100% in remote areas
  • FastLane feature uses both WiFi bands to establish one super high-speed connection
  • Connect up to five devices like gaming consoles, smart TVs, and more to your WiFi network at gigabit speeds.
  • Wirelessly share your media files with any device on your network
  • Print documents & photos to any USB printer connected to the extender
Special Features
  • Next Generation WiFi—Create faster dual band WiFi access with 802.11ac technology up to 1200Mbps.
  • Ultimate Range—700 mW high-power amplifiers & high-gain 5dBi antennas for maximum WiFi coverage.
  • Blazing Fast CPU—Powerful dual core ARM A9 processor enables maximum WiFi throughput at Gigabit speed.
  • 5 Gigabit Ethernet Ports—Connect up to 5 wired devices like Blu-ray players, game consoles, smart TVs or streaming players to your WiFi network.
  • Beamforming+—Focuses WiFi signals directly to wireless devices for more reliable connections.
  • FastLane Technology—Use both WiFi bands to establish one super high-speed connection; ideal for HD streaming & gaming.
  • Readyshare USB—Wirelessly share & access USB storage connected to the USB 3.0 port.
  • Wireless Printing—Print documents & photos to any USB printer connected to the WiFi Range Extender. WiFi coverage
Specifications
  • WiFi Technology - 802.11ac
  • WiFi Tech and Range - AC1200 (300 Mbps+900 Mbps)†
  • WiFi Band- Dual Band 2.4 & 5GHz
  • Number of Ethernet Ports - Five (5) 10/100/1000 Ethernet ports with auto-sensing technology
  • Number of USB Ports - One (1) USB 3.0 port
  • Dimensions: 9.92 x 6.85 x 1.22 in (252 x 174 x 31 mm)
  • Weight: 0.67 lb (302 g)
Key Features
  • Extends 2.4 and 5 GHz WiFi signals from existing WiFi routers for better range
  • Powerful 800 MHz dual core processor
  • 700 mW high-power amplifiers
  • 5dBi high-gain antennas
  • Beamforming+ for improved reliability
  • FastLane™ feature provides high-speed WiFi on both wireless bands and is ideal for HD gaming and video streaming
  • Ease of Use - Push ‘N’ Connect using Wi-Fi Protected Setup®(WPS)1
  • Power on/off button
