AC1750 Nighthawk AC1750 Smart WiFi Router R6700
3 posts / 0 new
desmvp
AC1750
Nighthawk AC1750 Smart WiFi Router R6700. i just got this router from costco thinking it was the ac1700 but i do like it.  the only reason i am sad with it is that there is no open sourced firmware for it so the big question on my mind is...... will there be open sourced firmware for the ac1750? if so how can i help? should i take it back and get the ac1700?
Bruintechie
There now is a DD-WRT build
There now is a DD-WRT build for it.
Check out:
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=268918
JeffreyThomas
I need to know which product
I need to know which product is the best from the ones listed on the site?
https://bestoffsetsmokers.com/best-traeger-grills/
