Considering Alternate Firmware - Thoughts Please
9 posts / 0 new
Haselsmasher
I have a WNR3500L and I'm considering going to one of the open source firmware sets.  In general this router running the Netgear firmware is meeting my needs - but there are a couple of issues I'm having that I'd be interested to hear people's opinions as to whether a different firmware might improve the situation.
  • We recently completed some basement construction and the router is now in a closet where range seems to be reduced.  I haven't yet tried different channels - and I'll do some experimenting with that.  Do the open source firmware sets provide more flexibility with radio configuration where this might be improved?
  • I do backups to an external hard drive connected to the router.  Readyshare performance is horrible, IMHO.  Is external hard drive performance improved with DD-WRT or Tomato compared with Readyshare?
  • Is there FTP hard drive access with DD-WRT or Tomato?
  • Do DD-WRT and/or Tomato allow *multiple simultaneous* VPN passthrough?  Both my wife and I need VPN passthrough at the same time.  I may be showing my age - but I've had routers that claimed VPN passthrough - but it was only one session at a time.  Maybe that's an issue of the past.
Any comments on the above "requirements" and which, if any, of the open source firmware sets might be best, I'd VERY much appreciate.
Jim
Brandon C
You probably will not see any
You probably will not see any improvements on wireless range or USB connected device speed with a different firmware.
I haven't tried your last 2 questions but its pretty easy to switch back and forth between firmwares. Might be worth the effort to give one or two a try.
Subhra
Do you want to just attach a
Do you want to just attach a HDD and copy files through ftp ?? If yes, then ddwrt is able to perform that.
Mainly people uses the OpenSource firmwares because of reach feature set and easy configuration through WebUI.
As Brandon said its pretty easy to revert back to Stock firmware and use "Restore Saved Settings" option to get back all your configurations in Stock firmware.
Haselsmasher
Well - since starting this
Well - since starting this thread I went to DD-WRT. I first bought a secondary router and using WDS connected it (running DD-WRT) to my primary router running stock firmware. The stock firmware, however, only allows WEP when using WDS. I wanted something more secure. So I flashed the primary router to DD-WRT as well, and then connected both DD-WRT devices using WDS. It's working fantastically well. The client router acts as a secondary access point, and the routers figure out which access point for a given client to connect to - depending on signal strength. Single SSID, single security. It's awesome.
Jim
Subhra
@Haselsmasher: Its nice to
@Haselsmasher: Its nice to hear about your experience about WDS.
What is your experience about "FTP hard drive access"?
Haselsmasher
The FTP hard drive access
The FTP hard drive access works just fine. My preferred backup prog is Syncback. I've been using it for a while and so it's familiar to me. Unfortunately Syncback is known for having wonky FTP capabilities. And that seemed to be the case with DD-WRT's FTP server. Syncback would hang sometimes. It's unfortunate - because Syncback is AWESOME when using network drive letter access, but weird with some FTP servers. I tried many freeware FTP backup programs as alternates to Syncback and didn't like any as much as I like Syncback.
So - I installed Optware on my router and got Samba running to get me network drive access. And I'm continuing with Syncback via network drive letter access.
Things are working great. DD-WRT is just awesome.
Jim
Subhra
Great to hear about your
Great to hear about your experience. Keep us sharing it.
Haselsmasher
I'm running v24-sp2. It's
I'm running v24-sp2. It's dated 8/7/2010.
It's running very very well.
Jim
tomekszy
Hi, I'm new here and I just
Hi, I'm new here and I just got WNDR3400 V1H2 (v1 refurbished) router. I never had a chance to knew Shibby's Tomato, that's why I need your help
I wanted to upgrade my router to use it as Bittorent and DLNA server, which was not possible in original FW, so I installed Tomato from http://www.linksysinfo.org/index.php?threads/netgear-wndr3400-v1-beta-to... 1st post (wchich was bad move, because there exist a newer one at http://tomato.groov.pl/download/K26RT-N/build5x-128-EN/Netgear%20WNDR-se...). The firmware works very well, it's obviously better than the original, but the Bittorent option doesn't work (I read there is only GUI for it) and there is no DLNA support, so I have few questions:
1a. Can I flash for example tomato-K26USB-1.28.RT-MIPSR2-128-BT.trx firmware to my router, and will it work? Is there some problems with that firmware in this router for example 5GHz don't work or some stability issues? Does it fit in router's flash?
1b. Does this firmware includes working Bittorent client and DLNA server? What is the diffrence between this and for example tomato-K26USB-1.28.RT-MIPSR2-28-BTgui-VPN.trx firmware? I already checked that it shoul be (I think) MIPSR2 version, not the MIPSRV1, am I correct? I read, that version tomato-WNDR3400-K26USB-NVRAM64K-1.28.RT-N5x-MIPSR2-128-MiniIPv6.chk doesn't have this things, because it's a mini version
1c. How should I do this? Can I upgrade via GUI (i'm afraid to experiment, my router is still in foil ;) )? There is information, that I shouldn't do that, but maybe is possible if I'm upgradind Tomato to newer Tomato? Can I do upgrade via commands, not GUI that will pass the thing when I brick the router :) I'm a little bit afraid.
2. If firmware 101 is only one I can get, how to install missing packets? I found, that I have to install ipkg, but this is very complicated for me. Also I'm not sure if it could show DLNA server in GUI (I think, that it should work with Bittorent, as there is a GUI option for it)
3. Is there a possibility to do things I want using DDWRT firmware?
4. How could I do this using as little Linux interface as possible ;)
Yes, I tried looking this in Google :)
TIA for all the help!
