So I decided to try out the Openwrt firmware but now the router doesn't boot so I am currently stuck.
I found out that one could flash the stock firmware through tftp, I suppose the one that ends with an .img?
I downloaded it from Netgear support site.
Nothing seem to happen.
In the tftp client I enter
192.168.1.1 as the server and as for the password, I just type the word password and nothing else.
Am I missing something?
The tftp client doesn't get any response from the router.
Any tips on what to do now?
Many thanks!
I had success with this way PAGE. you just need to be sure that you got static IP and the best AV/Firewall deactivated. Than it should work.
