Newbie Questions
3 posts / 0 new
nanias
Newbie Questions
Hello there guys I  came across this forum because I want to use my router to connect to a vpn sevice so all my connected devices use the tunnel to surf the web, but the factory firmware doesn't allow for client vpn connections.
Is this possible using the DD-WRT firmware for Netgear R7000 Based on resivion 2514 available on the downloads section?
I am currently on factory firmware V1.0.6.28_1.1.83 can I flash the above file to my router as is (after factory reseting it)?
If I want/need to restore the factory firmware where can I get it and what are the steps to do that?
Cheers
Sayan Mukherjee
Yes it is possible in DD-WRT
Yes it is possible in DD-WRT firmware.
kgwortman
You can also restore back to
You can also restore back to factory firmware from DD-WRT.....check out this link for instructions.....
http://ephams.com/2013/02/14/reverting-router-firmware/
