I'm running through my ISP's router in bridge mode, I've rebooted it all (disconnecting all connections etc, waiting, rebooting). Checked connections to make sure they are working (they are, which is how I'm online now).
I then had this connected to the R7000 with DD-WRT, with a VPN (PIA) running. When I changed the DNS servers everything went to hell. I cannot connect at all to the router now (via wireless or ethernet). I keep getting an unidentified network and limited connection and cannot access the GUI through browser (yes I have cleared the cache). I also tried running ipconfig but there is no default gateway listed.
Website security can be a complex and even confusing topic because of its ever-evolving landscape, for that reason, it’s important to keep in mind that security (especially website security) is never a set-it-and-forget-it solution.
Reboot the device if it is obtaining IP address dynamically. Clear the browser's cache and then try accessing GUI.
Good luck!!
Thanks but no dice. Any other suggestions? I'm desperate to get this back working.
A bit more background.
I'm really stuck. Help me ObiWan!!
Tried 30-30-30 hard reset. no luck. HELP PLEASE!!
