How do I give my wifi a password?
2 posts / 0 new
iJartus
When I log on to my wifi with a wireless device my wifi is open to the public. I need to make it private for my household only.
Mastec
Log into your routers
Log into your routers wireless settings.  Then change your security option from None to either  WPA-PSK [TKIP], WPA2-PSK [AES] or WPA-PSK [TKIP] + WPA2-PSK [AES].  Your options may look different but this will give you an idea of how to do it.  Once you add the security you will be prompted to add a password.
