I setup my R7000 with this firmware: DD-WRT v3.0-r28514 std (12/28/15)
I also added entware and various options (ntpd, named) to get it to work the way I want. All running from a USB stick.
It worked fine for about 2 months, then I started getting random reboots.
Nothing in the logs to indcate the problem.
I added some monitoring scripts of my own to ensure it wasn't running out of RAM, running too many procs, etc. It wasn't.
Believing the problem to be hardware, I purchased another unit and set it up the same way.
After 24 hours it started random rebooting too.
The only common hardware components are the DC power unit (which I will now swap out), and the USB stick.
Since it runs Linux, I'm 99.9% confident that none of non-kernel processes (ntpd, named, cron, etc.) can cause it to crash.
Is this a driver issue? I've read aout Broadcom driver problems from about a year ago.
Unfortunately, there never seems to be any release notes with the new DD-WRT builds, so I have no idea whether it's worth install new firmware.
Any suggestions?
install newer firmware, this should fix the issue, if you ever run in to any problem like this again, it is 99% of the time, the firmware, sadly the R7000 is not a true open router, DD-WRT do not support it, but a guy is making the firmware work on the R7000, meaning more things can go wrong, as hes the only one working on the project
@SignedAdam: DD-WRT does support R7000
I finally got around to upgrading to the latest DD WRT release, and the problem is solved.
