Hey All,
New hear hoping someone has the answer.
Flashed initial tomato to stock firmware on my netgear R8000.
Then upgraded to latest Arm-137 AIO . RIght after that stuck in boot loop.
Tried multiple resets does no luck.
Started continuous ping.. After 15seconds I get 4 pings from router and then nothing.
Hook up my usb-ttl. Can see boot sequence but cant break boot with Ctrl+C .
Tried many times and nothing. Tried with flow control on and off.
Do I have a new door stop?
Or does anyone know a way around this?
Thanks guys
I'm sorry but I have a hard time following what you're saying. Can you explain in proper English, please? The flashing process is a very delicate procedure so we need to know the exact steps done, preferably in proper English
Thanks for replying microchip.
I have an R8000 that when powered on has amber power light.
If I set a constant ping to it, I will get a total of 4 TTL=100 back but thats it.
I have tried tftp an image file to it via windows, and I have also tried using usb-ttl adapter.
When using the serial connection I see the boot sequence, I keep hitting CTRL-C but never get the CFE prompt.
Is there any other process anyone knows about to de-brick?
Below is also the out put when connected to serial.
I have been hammering ctrl-c from instant it turns on until reboot with no luck getting the CFE prompt.
Decompressing...done
Digital core power voltage set to 1.0V
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001D3
000013C0
RDLYW0 00000004
RDENW0 00000034
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
01 --------------++++++++++++++++++++++X+++++++++++++++++++++------
02 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
03 --------+++++++++++++++++++++++X++++++++++++++++++++++----------
04 ----++++++++++++++++++++++X++++++++++++++++++++++---------------
05 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
06 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
07 ------------++++++++++++++++++++++X++++++++++++++++++++++-------
08 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
09 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----
10 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------
11 -------------+++++++++++++++++++++++X++++++++++++++++++++++-----
12 -----+++++++++++++++++++++++X+++++++++++++++++++++++------------
13 ------------++++++++++++++++++++++X++++++++++++++++++++++-------
14 --------+++++++++++++++++++++++X+++++++++++++++++++++++---------
15 ------------+++++++++++++++++++++++X++++++++++++++++++++++------
PW0
00 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
01 ---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------
02 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
03 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
04 ++++++++++++++++++++++++X++++++++++++++++++++++++---------------
05 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
06 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
07 --+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------
08 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
09 ----++++++++++++++++++++++++++++X++++++++++++++++++++++++++++---
10 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
11 ----++++++++++++++++++++++++++++X++++++++++++++++++++++++++++---
12 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
13 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
15 ---++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
NW0
00 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
01 -------------++++++++++++++++++++++++X+++++++++++++++++++++++---
02 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
03 --------+++++++++++++++++++++++X+++++++++++++++++++++++---------
04 ----+++++++++++++++++++++++X+++++++++++++++++++++++-------------
05 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----
06 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
07 ------------++++++++++++++++++++++++X++++++++++++++++++++++++---
08 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
12 -----++++++++++++++++++++++++X+++++++++++++++++++++++-----------
15 -----------+++++++++++++++++++++++X+++++++++++++++++++++++------
WRDQW0
00 +++++++++++++++++++++++X+++++++++++++++++++++++--------++++++++-
01 ++++++++++++++++++++++++X++++++++++++++++++++++++-------+++++++-
02 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
03 +++++++++++++++++++++++X++++++++++++++++++++++--------+++++++++-
04 +++++++++++++++++++++X++++++++++++++++++++-----------++++++++++-
05 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
06 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
07 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
08 +++++++++++++++++++++++X++++++++++++++++++++++---------++++++++-
09 -+++++++++++++++++++++++X+++++++++++++++++++++++-----------++++-
10 +++++++++++++++++++++++X+++++++++++++++++++++++---------+++++++-
11 ---++++++++++++++++++++++X++++++++++++++++++++++-------------++-
12 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
13 --+++++++++++++++++++++++X+++++++++++++++++++++++-----------+++-
14 ++++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
15 --+++++++++++++++++++++++X++++++++++++++++++++++------------+++-
WRDMW0 00000022
WRDMW0 00000024
ADDR
00 +++++++++++++++++++S+++++++++++X++++++++++++++++++++++++++++++++
CFE for Foxconn Router R8000 version: v1.0.8
Build Date: Fri May 30 15:03:06 CST 2014
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0: hwaddr E8-FC-AF-F9-69-A8, ipaddr 192.168.1.1, mask 255.255.255.0
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: .... 4304128 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 29
0x000000200000-0x000004200000 : "linux"
0x0000003b4d28-0x000004000000 : "rootfs"
0x000002200000-0x000002240000 : "board_data"
PPTP driver version 0.8.5
=== PPTP init ===
u32 classifier
Actions configured
nf_conntrack version 0.5.0 (3989 buckets, 15956 max)
ctnetlink v0.93: registering with nfnetlink.
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
Registering the dns_resolver key type
NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
0x000004000000-0x000008000000 : "brcmnand"
devtmpfs: mounted
Freeing init memory: 216K
Hit ENTER for console...
ctf: module license 'Proprietary' taints kernel.
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0x400
et_module_init: et_rxlazy_timeout set to 0x3e8
et_module_init: et_rxlazy_framecnt set to 0x20
fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)
fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)
dhd_module_init in
dhd_queue_budget = 256
dhd_sta_threshold = 2048
no wifi platform data, skip
PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)
PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
DHD: dongle ram size is set to 983040(orig 983040) at 0x180000
dhd_attach(): thread:dhd_watchdog_thread:2f6 started
dhd_deferred_work_init: work queue initialized
Dongle Host Driver, version 1.194.33 (r526004)
Compiled in drivers/net/wireless/bcmdhd on Jun 17 2015 at 11:27:36
Register interface [eth1] MAC: 00:90:4c:11:22:33
dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-chkd2hdma-proptxstatus, 2015.06.17.111523, 2015/06/17 11:15:23).
dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.
dhdpcie_readshared: address (0xfe1a01e5) of pciedev_shared invalid
Waited 5006383 usec, dongle is not ready
dhd_bus_init :Shared area read failed
dhd_bus_start, dhd_bus_init failed -1
dhdpcie_init: dhd_bud_start() failed
Enforcing kernel panic
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 817 [#1] PREEMPT SMP
last sysfs file: /sys/kernel/uevent_seqnum
module: dhd bf02e000 799274
module: et bf01b000 48925
module: igs bf013000 11927
module: emf bf00a000 15169
module: ctf bf000000 16424
Modules linked in: dhd(+) et(P) igs(P) emf(P) ctf(P)
CPU: 1 Tainted: P (2.6.36.4brcmarm #3)
PC is at dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]
LR is at dhdpcie_bus_process_mailbox_intr+0x17c/0x1e8 [dhd]
pc : [<bf041440>] lr : [<bf041460>] psr: 20000113
sp : cf83ded0 ip : c044aee4 fp : 00000000
r10: c003c1d4 r9 : c0450f20 r8 : c0455cd8
r7 : bf05cd00 r6 : 00000000 r5 : 00000100 r4 : cf9d3000
r3 : 00000000 r2 : cf83c000 r1 : 60000113 r0 : 00000019
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 8fb8004a DAC: 00000017
Process swapper (pid: 0, stack limit = 0xcf83c270)
Stack: (0xcf83ded0 to 0xcf83e000)
dec0: 00000000 cf9d3000 00000000 b83ef180
dee0: cf83c000 cf9d3000 00000100 00000000 cf83c000 bf051d08 00000100 bf05cd00
df00: ce680000 ce683898 00000000 bf03324c ce683894 c006955c c0069450 00000001
df20: c0400058 cf83c000 00000103 c003c148 c0400040 c0450f20 00000001 c03c1330
df40: d0810000 c0057c94 00000006 0000000a 00000008 cf83c000 c0455cd8 c003c9d0
df60: cf83c000 00000000 cf83c000 0000001f 00000000 c0069d00 000000a3 c03c0ec0
df80: ffffffff f0100100 000000a3 00000002 00000001 c03c09e8 00000002 cf922d00
dfa0: cf83dfe0 00000000 cf83c000 c04230a8 c040ab80 c0423214 80000000 413fc090
dfc0: 0000001f 00000000 00000000 cf83dfe0 c003fbe4 c003fbe8 60000013 ffffffff
dfe0: c003fbc4 c003fd88 8f84806a 0000001f 10c03c7d 80008148 ed57ffef ffffffff
[<bf041440>] (PC is at dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd])
[<bf041440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]) from [<bf051d08>] (dhd_bus_dpc+0xc8/0x150 [dhd])
unwind: Index not found bf051d08
Code: e5973000 e3130001 1a000006 e3a03000 (e5833000)
---[ end trace 42161ca811e67e97 ]---
Kernel panic - not syncing: Fatal exception in interrupt
[<c0044ff8>] (unwind_backtrace+0x0/0xf8) from [<c02f979c>] (panic+0x7c/0x1a8)
[<c02f979c>] (panic+0x7c/0x1a8) from [<c00426f8>] (die+0x1ac/0x1dc)
[<c00426f8>] (die+0x1ac/0x1dc) from [<c0046390>] (__do_kernel_fault+0x6c/0x8c)
[<c0046390>] (__do_kernel_fault+0x6c/0x8c) from [<c0046500>] (do_page_fault+0x150/0x1ec)
[<c0046500>] (do_page_fault+0x150/0x1ec) from [<c003e3a4>] (do_DataAbort+0x30/0x9c)
[<c003e3a4>] (do_DataAbort+0x30/0x9c) from [<c03c098c>] (__dabt_svc+0x4c/0x60)
Exception stack(0xcf83de88 to 0xcf83ded0)
de80: 00000019 60000113 cf83c000 00000000 cf9d3000 00000100
dea0: 00000000 bf05cd00 c0455cd8 c0450f20 c003c1d4 00000000 c044aee4 cf83ded0
dec0: bf041460 bf041440 20000113 ffffffff
[<c03c098c>] (__dabt_svc+0x4c/0x60) from [<bf041440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd])
CPU0: stopping
Rebooting in 3 seconds..[<c0044ff8>] (unwind_backtrace+0x0/0xf8) from [<c003e334>] (do_IPI+0x114/0x154)
[<c003e334>] (do_IPI+0x114/0x154) from [<c03c09e8>] (__irq_svc+0x48/0xe8)
Exception stack(0xc03fff78 to 0xc03fffc0)
ff60: c8207020 cf9e3600
ff80: c03fffc0 00000000 c03fe000 c04230a8 c040ab80 c040ab78 80000000 413fc090
ffa0: 0000001f 00000000 00000000 c03fffc0 c003fbe4 c003fbe8 60000013 ffffffff
[<c03c09e8>] (__irq_svc+0x48/0xe8) from [<c003fbe8>] (default_idle+0x24/0x28)
[<c003fbe8>] (default_idle+0x24/0x28) from [<c003fd88>] (cpu_idle+0x70/0xa4)
[<c003fd88>] (cpu_idle+0x70/0xa4) from [<c0008e8c>] (start_kernel+0x3cc/0x42c)
[<c0008e8c>] (start_kernel+0x3cc/0x42c) from [<80008148>] (0x80008148)
Just a shot in the dark, but have you tried pressing "enter"?
lol ^
