I can't access R7000 Help
10 posts / 0 new
whopper
whopper's picture
I flashed my R7000 with Advanced tomato and have been using it for almost a year with PIA VPN.  Today I tried to create a wireless client on it to attach to my Apple Router and I changed the routers IP to 10.0.0.1.  I saved it rebooted and now I can't connect
What have I done?  What can I do to fix the issue
John
microchip
microchip's picture
do you get a 10.0.0.x IP on
do you get a 10.0.0.x IP on the PC you're trying to access it, or does it still have a 192.168.1.x IP?
whopper
whopper's picture
 I get the following with
 I get the following with ipConfig
Autoconfig IPv4 address: 168.254.217.186
Subnet : 255.255.0.0
microchip
microchip's picture
that's an autoconfig, not
that's an autoconfig, not coming from the router. Best is to hard reset it so you can connect back to it
whopper
whopper's picture
So how do you recommend doing
So how do you recommend doing the Hard Reset?
I have tried what I know... any suggestions would be appreciated
microchip
microchip's picture
there's a small hole at the
there's a small hole at the back of the unit (labeled Reset). Press it for at least 10 seconds, until the power led starts blinking
whopper
whopper's picture
Thanks that worked
Thanks that worked
I upgraded to Advanced tomato v3.3 by chance would you know how to create a wireless client on tomato to connect to my apple airport extreme?
microchip
microchip's picture
No idea on that one, sorry
ammy
ammy's picture
Doesn't work at all. Plugged
Doesn't work at all. Plugged into my computer and the setup screen doesn't come up. OK, I think, I'll use the mywifiext.com and mywifiext.net sites that they suggest as a backup. Neither site is live. Just connection errors.
microchip
microchip's picture
@ammy
@ammy
what are you talking about???
