Hello, I was using Kong firmware on my R7000 for more than a year. I try to upgrade to the Tomato firmware however after I flushed my router with the tomato-R7000-Initia.chk I'm not abl to log into my router. Any suggestion?
Supply chain attacks, ransomware attacks, phishing, data breaches; all these types of attacks are on the rise, thanks to the expansion of the connected world. With greater expansion comes greater security risk.
I do not see it on Shibby's download site. From where did you get this from?
After I update the netgear firmware from tomato, all of the routerinfo were lost. so if you want to update tomato, you must make a backup at first.
Telnet the router, use the following commands and your backup to save your router.
also I cannot reset the router using the reset button...
Is it possible to load tomato on the Router Netgear R7800 and linksys 1900acs? Because of multiple OPENVPN Client profile support at the router.
Hello, What Tomato version should i donwload for this Router
Netgear R6400-100PES(AC1750 Smart Router)WIFI AC1750 Mbps Dual Band.
