NETGEAR R7000 "Kong Mod" Updated 06-27-2016 crashes every 10-15 minutes. No connection to default-gw (which is the R7000), from WLAN and LAN. Turn power off -> on, then it works again for 10 - 15 minutes, then same problem...
I'm having similar problem. After updating to most recent Kong Mod 06-27-2016 my router crashes a lot more. I see the WiFi but can't connect. I go to my wired connection and get no ping reply. I power cycle and then can connect for a while. Usually crashes within 24 hours of power cycle.
same thing here any solutions? Coz I hav several smart home devices and that becomes a problem
If you can't connect, that is known as a brick. Time for the serial cable. Reflash.
