after considering it for a while, i finally jumped in and joined you guys in the ddwrt world with a R7000, and i might say i enjoy it.
one of my main use is openvpn client for my network, however, i don't want to run ittt all the time, especially ince it impacts my DL speed a lot (steady 100Mbs without, 15 with vpn on, and i have a LOT of steam games)
so i switch the vpn off when updating, but it's not "user friendly" having to go in the web server, loggin, etc... so i decided to try using the WPS button to toggle the vpn.
after playing and reading a lot, i came up with this solution:
create a script "vpn_toggle.sesbutton"', store it in /jffs and copy it to "/tmp/etc/config" using startup script
startup script:
mkdir /tmp/etc/config cp -f /jffs/vpn_toggle.sesbutton /tmp/etc/config/
vpn_toggle.sesbutton script:
#!/bin/sh if [ $(cat /sys/class/net/tun1/carrier) -eq 1 ]; then killall openvpn gpio disable 14 else openvpn --config /tmp/openvpncl/openvpn.conf --route-up /tmp/openvpncl/route-up.sh --route-pre-down /tmp/openvpncl/route-down.sh --daemon & gpio enable 14 fi
and it works...well, kinda.
it does actually toggle on or off the vpn & WPS led, as expected, BUT once toggled OFF, the vpn is somehow restarted after a few minutes.
so obviously, something is watching about the vpn and restarts it.
so i am wondering how to actually properly toggle it off from a script, so if anyone has a clue or better, a solution, i'd be glad to hear about it :)
There is definitly a problem if you are seeing that much of a gap in speed. If your VPN provider is not helping you with the problem, try using Torguard, they have a great support staff.
hi and thx for the advice, the speed issue will be dealt with, either from help with the provider support or switching to another provider, altough i doubt any provider be able to provide 100Mb/s openvpn tunnel.
but my question remains, regardless of the speed issue, i still want the ability for other purposes to switch easily the vpn on and off
