Hello
I use this firmware http://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-wnr3500lv2-... but i found a problem on boot router
Here is the error
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.89.21 (r524987)
loading bcm57xx
insmod: bcm57xx.ko: module not found
loading switch-core
Do you have a solution to this problem because the router does not. The switch is not recognized and so the firmware is invalid.
The 2012 firmware works but not in 2015.
Too bad.
How to compilier BCM47XX module with the kernel in 3.X?
I go back it. Do you have an idea ?
