Ethernet ports
5 posts / 0 new
ray77
Ethernet ports
Hi guys,
I having been having this issue from a few days back not sure what happened but I had my Telstra cable modem in bridge mode and hooked up to my Netgear R7000 and it has been working fine for the last 4-5 months.  But as of 2 days ago for some reason, my Netgear router will not detect my WAN  ethernet cable or any other ethernet cable except for one ethernet cable that is connected to my Nas when I have any cable plug in no lights come up  can some please help me fix this thanks.
stro3579
In am having the same issue
In am having the same issue with my Netgear R7000  1,2,4 lan ports work, but not lan port 3.  The light doesnt come on either.  I am new to DD-WRT.  I just flashed my router Saturday, 11/12/16.
ray77
Here is an update i have got
Here is an update i have got it working but LAN1 & LAN 2 are not working but LAN 3 & LAN4 are working not really sure what's going on
stro3579
So you have all of the ports
So you have all of the ports working now?  If so what was the issue??  Mines is still not working.
ray77
No i don't have all the ports
No i don't have all the ports working i only have 2 ports working out of the 4 on the router not really sure why they are not working
