Logging software
3 posts / 0 new
unimorpheus
unimorpheus's picture
Logging software
Due to the growing use and complexity of my network as well as some extra available hardware it's time to move router logging to a bigger more robust host. I have been looking at wallwatcher and link logger but both of these tools seem to be very out of date and unsupported. I don't know if any of them will run in Win10 although I can use Win 7 for now (until MS kills Win 7 support which will probably be tomorrow). Are there any modern alternatives or is this effort effectivly dead. Is the monitoring/logging market for consumer grade routers dead? Thanks for the input.
microchip
microchip's picture
it would be helpful if you at
it would be helpful if you at least mention which router model you have and which firmware you're running :)
unimorpheus
OK........ Software
OK........ Software configurable to router but here goes. WNDR4500v2 running DD-WRT v24-sp2 (11/19/14) std. I think I have located several good candidates but thanks anyway.
