Hi guys!
I am running Shibby´s Tomato on my R 7000 and have tried both the older, as well as the more recent version. I want to set up the OpenVPN client to connect to my VPN Provider, Cyberghost. However I get the following error in Syslog:
Nov 25 13:53:59 unknown daemon.notice openvpn[6936]: OpenVPN 2.3.4
arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on
Jun 9 2014
Nov 25 13:53:59 unknown daemon.notice openvpn[6936]: library versions: OpenSSL 1.0.1h 5 Jun 2014, LZO 2.06
Nov 25 13:53:59 unknown daemon.err openvpn[6936]: ERROR: could not read Auth username from stdin
Nov 25 13:53:59 unknown daemon.notice openvpn[6936]: Exiting due to fatal error
This is my custom configuration:
client
remote 4-us.cg-dialup.net 8080
dev tun
proto udp
auth-user-pass
resolv-retry infinite
redirect-gateway def1
persist-key
persist-tun
nobind
cipher AES-256-CBC
auth MD5
ping 5
ping-exit 60
ping-timer-rem
script-security 2
remote-cert-tls server
route-delay 5
tun-mtu 1500
fragment 1300
mssfix 1300
verb 4
comp-lzo
ca ca.crt
cert client.crt
key client.key
And these are the configurations in "client 1" > "basic":
- Start with WAN: Disabled
- Interface Type: TUN
- Protocol: UDP
- Server Address/Port: Address: 4-us.cg-dialup.net Port: 9081.
- Firewall: Automatic
- Authorization Mode: TLS
- Username/Password Authentication: Enabled
- Username Authentication only: Disabled
- Extra HMAC authorization: Disabled
- Create NAT on tunnel: Enabled
These are the configurations in "client 1" > "advanced":
- Poll Interval: 0 (deactivated)
- Redirect Internet traffic: Enabled
- Accept DNS configuration: Relaxed
- Encryption cypher: AES-256-CBC
- Compression: Enabled
- TLS Renegotiation Time: -1
- Connection retry: 30
- Verify server certificate: Disabled
I have already checked my password and username. I have also set the time server to US and the time zone to pacific time. I really would appreciate any help you could give me, since this problem is far beyond my thechnical expertise :-)
Regards!
Gonzo
Did you ever get this working?
I am having the exact same issue (albeit with a Linksys E2500)
I've got Cyberghost running on my R7000, with DD-WRT v3.0.
Took some troubleshooting but found that by removing the following items in the config all works great:
auth-user-pass (this was a spurious extra line put in for some reason)
dev-tun
ca ca.crt
cert client.crt
key client.key
Once I removed those 5 items, everything connected and runs for days.
Hope this helps someone.
Glau
