NAT Loopback not working
2 posts / 0 new
sauger100
I am using DD-WRT build 30020M from Kong on my R8000 and I'm very happy with it, but there's one issue: I can't get NAT loopback working.
I unchecked "Filter WAN NAT redirection" under Security -> Firewall, but it still isn't working.
Is there any way to get this working?
Thanks in advance!
JohnoB
Ok - Fixed my own problem
Ok - Fixed my own problem after sleeping on it.   The issue was that I had the address without the corresponding port.
Eg: http://abc.abc.net did not work.    http://abc.abc.net:8080 worked.
Hopefully this will help out others in the future.
Regards
John.
